Need some help please! Drone would not return home.
Ok, well round up a bunch of friends, put the beer on ice, and start the hike. The last recorded point was 4311 feet out from the HP. I think I'd start there. Good luck!
I was using dronedeploy today and the drone seemed to have lost connection to the link so I initiated an RTH (returntohongkong) yet the P4P did nothing and would not return. (yes I did hold down the button until it started beeping :)
Attached are my flight logs. Any and all help would be greatly appreciated.
I'm confused by your story. You haven't given much in the way of details.
I'm wondering if that flight record you've linked is from the flight in question or from an unrelated flight?
Have you used DD previously or was this a first experience?
It would be interesting to see what you had programmed DD to do.
Can you post a screenshot of the DD mission screen?
Finished the mission?
That suggests to me you had a waypoint mission in progress in which case RTH on signal loss is inhibited so it can complete the mission. Waypoint missions are uploaded to the AC where the AC handles the program, not the RC or app. I believe it will return on low battery however. If during the mission it hit an obstacle, then of course it won't return at all.
What's the odds it just took off and landed miles away?
Don't know. As I said, I'm unfamiliar with DD. But in cases like this is why I have a tracker on my bird. But that's another story.
So, please let us know the outcome of today's search. And try to answer Meta4's questions above. We are all trying to help you locate your wayward bird.
All this is from the flight in question. I would not post another unrelated flight :) I use DD on a weekly basis. I can't post a screenshot of my DD mission due to the confidentiality of the mission and exact location. What I can say is after a day of hiking in the P4P was recovered. NOW I just need to figure out what caused this issue.
Reactions: captainmilehigh
Without giving any details to work with, you're going to have to work it out yourself.
Reactions: Pharm
Good thing I already found it then :) It was not easy and just so everyone knows for the future DJI uses an odd horizontal datum that is extremely inaccurate. The P4P was nearly 100M away from the lat/long provided.
Can you give any further details of that?
Do you mean it was more than 100m away from the last point in the flight record ?
If so it's not surprising as when the Phantom was at that point, it was 138 feet higher than launch point and moving south at 18 mph.
It would be expected to have continued southwards after signal was lost.
So are you saying that DJI uses an unusual datum or were you just expecting the Phantom to be at the last recorded position?
Sorry, should have been more specific. The P4P was hovering for 15 mins in the same spot according to the logs. If you PM me I will send you what I am referring to :) It was 100M away from that spot.
Sounds like you not only lost your drone, but that you had lost your VLOS well before your drone went down. If your setting was to RTH if the controller/drone signal connection is lost and your altitude to return was above all obstacles, it should have returned. If it was within your VLOS, you would have recovered it by now. It it had crashed, you would have seen exactly where.
akos9703
