need help installing tilt on good buy gimbal
Have everything hooked up working good but can't seem to figure out the tilt control. I know I have the wires. I have 6 pins on the gimbal. I know I gotta hook it up from the pitch pin to the f2? Someone please help before I throw it through the window here are some pics of what I got going.
Welcome to the forum jamesjdalton, a little late, I know.
It looks like you have a green wire plugged into F2 and a red wire into F1. That's not what I did on my cheap Chinese gimbal.
Did you "turn on the gimbal pitch control" in the NAZA assistant?
When you do that, you can also calibrate your pitch control stick to work just the way you want it.
If you've already done the above, I suggest you search for a video using the following link.
Here's something that will help you find things in our forum.
It's Google Custom Search, enter your text in the middle of the page, not at the top.
https://cse.google.com/cse/publicurl?cx=014775389315664725445:ejku2ysgyhi
Enjoy the show.
I just need to know where the tilt wires connect got the power hooked up fine.
At the NAZA, the "PITCH" control wire connects to the F2 "BOTTOM" pin.
I do not know where it connects on your gimbal because you have not provided me with enough information to know which gimbal you have... Insert a LINK Please.
We're here to help, but it's impossible if we don't know what we're helping with. ;)
shimuafeni fredrik
