My drone goes out of control
I just replaced the total outer shell of my Phantom 4. Everythings shows on on the monitor. However When I launched it for the first time it went to the 4 foot lever then spun out of control. Any ideas whats wrong ? I inspected everything carefully but found nothing wrong. I did notice the voice dont come across stating " the home point has been established " So... any ideas whats wrong ?
A look at the flight data might help solve the mystery.
Go to DJI Flight Log Viewer
Come back and post a link to the report it provides
Found the problem with my drone crashing. I had cut one of the motors wires ( 3 wires ) because those wires were hard to get to on the board. A mistake on my part ! The insulation on the wires is almost impossible to remove ! However after I tried again to solder them I found a way to connect them. Strip the wires back about 3/8 inch. Clean them the best way possible. Then.. use a light duty braided wire and wrap the motor wires together.... end to end Then solder them. This acts as a splint to hold the solder in place. This time before allowing my drone to become a white tumble weed .....I held in in my hands and tried it out to see if all the motors were working. After placing the motors under a load for a few minutes and none of the motors got warm the connections are good !
When replacing P4 motors I’ll splice half way down the arm to keep from soldering onto circuit board, glad you caught your problem
hcashmore11
