I was stupidly flying this evening in the garden without the light on (forgot) and I was doing the manoeuvre where you go forwards for a bit then yaw round 180 and go the other way, kinda fun but I didn't notice that each time I was doing it I got closer to the bird table that I couldn't see...
It only barely hit it while I was turning at about 1 or 2 metres so I only broke 1 prop and got the phantom a bit muddy as it landed props down but I cleaned it up and it looked fine.
Replaced the prop and it flew perfectly fine but I stared to notice what I can only describe as a kind of rubbing/metal noise on one of the motors. So I took the props off and tested it by holding it and tilting it to rev up one motor or the other, and sure enough when tilted diagonally to one side, now I was only listening to the motors not the props, one motor sounded different(note: not the clicking or grinding others have reported).
I intend to replace the motor as it is quite cheap, but will not be able to replace it as I am away from home for a week.
Is it safe to fly for a few times with the motor like this until I swap it out?
Also any tips on replacing the motor? Haven't opened(or crashed) it before
