Mine is on it's way! Quick question
Discussion in 'Phantom 2 Vision + Discussion' started by skyexposure, Feb 2, 2015.
  1. skyexposure
    New Jersey
    So, just today I finally pulled the trigger and purchased at P2V+ V 3.0 kit.
    Comes with the Phantom, extra battery, extra props, and a pretty sweet case. Paid $1399. Decent deal I think.
    Anyway - quick question. Have any of you participated in the DJI Pilot Training Program? I read other places that it really isn't worth it and it's basically just a longer sales pitch on their different models.
    I am signed up for one this weekend, but I don't want to waste my time if it's not worth it since the training is about 3 hrs away.
    Thanks, and looking forward to getting to know you all a bit better in the near future.
  2. flyNfrank
    Indy, USA
    Welcome to the the vPlus forum. I was hoping to see you say you were going to pop the top and make sure your quad had the most recent parts. There is probably 4-6 videos you could watch from youtube, and then add all that you learned from reading through the manual, and then....what you will take in from actually flying your quad will supersede a training program.
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
    #3 msinger, Feb 2, 2015
  4. skyexposure
    New Jersey
    Thank you. I have watched about 3-4 hours of video so far, and read a bunch. I will certainly read the guides here and suggested as well. I don't think I will head down there for their "training program".
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Yep -- I wouldn't bother with that if I were you. You'll learn more here.
  6. Meta4
    Meta4 Moderator
    Staff Member
  7. skyexposure
    New Jersey
    Do you really think it is necessary to pop it open and check? I would rather not, but from what I read about some of the V 3.0 issues, I might. Then again, I read on here where someone else got theirs from B&H a couple weeks ago and everything seemed to be updated.
  8. bbfpv
    Long Island, NY
    Yeah I think B&H has sold out of the pre-holiday stock of questionable P2V+'s. I got the replacement for my fly away about 2 weeks ago, and while installing a Flytrex noticed the guts were all updated.
  9. flyNfrank
    Indy, USA
    Absolutely. It doesn't matter where it's coming from. You 1st mostly want to know that the ESC's have a v2.1 on each white label. Next you will want to just do a visual check to see that you have the vented wifi module with numerous holes in it's cover. See attached Image below.
    Next because there has not been any known fix for the GPS Connection Issue, you should do the quick 1 minute mod found in this link: viewtopic.php?f=27&t=30912&hilit=GPS+Connection+Issue
    That's it for under the top cover for now, unless you are ready to mount a GPS Tracker or the Flytrex Live 3G.
    There is no reason to delay opening the top cover. Some find they remove the cover 10 -15 times in the 1st two months. But removing the cover the 1st time for the reason it needs to be done is very important. I don't know how many times I have seen someone say they will wait and remove the cover if they have a problem, and the very next day post on here how their quad is now totally trashed.
    Btw, one small tip on installing the top cover again. Before you tighten and screws again, be sure to install the battery 1st. This will help with allowing the battery to be continue being easy to slide in & out. That's it, your done....
    [​IMG]
  10. skyexposure
    New Jersey
    Ok - will do before flight. I am sure I can get the appropriate screwdrivers at my local Ace, Lowes or Home Depot, right?
  11. davisual
    Tip...Take the small screws at the end of the arms out first with appropriate size phillips driver #1 to avoid routing out the screw head.
  12. flyNfrank
    Indy, USA
    You will get a green handle screw driver with your quad unless they changed to not including one.
    2mm alen wench.
  13. gcbuss
    . That is a good tip. I stripped one of those screws during my shielding the gps mod this weekend. It is a tiny delicate screw. I have a replacement set on order. Looking for a nice set of hex drivers.
  14. flyNfrank
    Indy, USA
    Even with a perfectly matched screwdriver you are going to strip out those screws. They need replaced with allen screws.
  15. gcbuss
    Have u replaced those with Allen screws? If so where did you get them from. I have ordered the replacement screw pack but I would guess it will have the same crappy little Phillips head.
  16. skyexposure
    New Jersey
    Thanks for the input guys. You've been helpful.
    I also just ordered a cheap Hubsan from Adorama with some leftover credit I had sitting there.
    I figure I can practice some indoors until NJ warms up a bit.
Similar Threads - Mine Quick question Forum Date
Video of the Week: AirVuz Drone Video Awards' Nominees! - DRONELIFE Photos and Video Jan 13, 2018
Coal Mine Canyon Photography and Film Dec 24, 2017
Idle Time... Motors, Not Mine. Phantom 4 Discussion Dec 13, 2017
mine and GIS software Pro/Adv Discussion Dec 5, 2017
Coal Mine Canyon in 4K60 Photos and Video Sep 11, 2017
