- Joined
- Jan 3, 2017
- Messages
- 15
- Reaction score
- 3
You use it to transfer pics and vids from the drone if you don't want to remove the sd card.
Neon Euc
The one on the gimbal is for transferring files from the Micro SD card, and the one on the front of the aircraft is for downloading flight logs when it is put in the correct mode.
Do you have to have the drone on to be able to access the functions?
For accessing the SD, you just need to turn the drone on. For getting the flight logs, which you would only need to do if you have problems, you would choose "Enter flight data mode" in the Advanced settings for the aircraft in the DJI Go app.What mode is the correct mode to put it in?
The OP was concerned with the ports on the 'bird' itself not the RCand of course charging the rc.
just don't want him loosing the cable if he isn't downloading through it.The OP was concerned with the ports on the 'bird' itself not the RC
