Crash, Startup Failure
So, while doing some testing with my P4 drone, things ended badly (only 3-4 feet off ground). Drone crashed, Broke one blade and now when I power on the drone, the gimbal does not do its diagnostics, it seems the motors do not self test, no light near the SD card slot, and no connection to controller. I tried connecting to USB for DJI Assistant 2 and no USB detection sound. I am leaning towards ESC boards, however may just be a loose cable(s) inside (need long shaft M6). Front LED on drone goes solid RED and rear flashes YELLOW quickly.
  • Wow
Reactions: Daniel NZDF
Opened drone and found one ESC cable slight shifted in connector. Realigned and inserted fully and re-assembled and inserted battery the battery went off when turned on. Re-inserted with battery turned on and the drone came back to life...controller was able to pair.
