If you need carbon fiber or fiberglass stuff let me know..i have a bunch..same with airbrush stuffHey pro conductive copper tape and tested continuity it's possible this may not be good enough and I might have to thinly solder over the lot testing will tell.
This is definitely a prototype and if all goes well I will be etching pcb and possibly vacuum forming cover and airbrushing.
Although this is just the beginning I've seen allot more powerful 19dBi ones so might move on to them after.
Hey Tony my guess it is just 2 patches but would be good to seeI would love to see the insides of the smaller 9db DBS/Itelite panel. Any takers?![]()
You know I do my best work at midnight but I'm down for the challenge. I think those images are already onlineI would love to see the insides of the smaller 9db DBS/Itelite panel. Any takers?![]()
Thanks pro I'll keep that in mind, I was looking at a carbon fibre starter kit not too long ago, cool stuff especially weight wise but the finish also once polished up is top notchIf you need carbon fiber or fiberglass stuff let me know..i have a bunch..same with airbrush stuff
Wow thats ace, gotta get me some carbon.Carbon fiber is sick..just finished this for an antenna bracket and more for the back of the reflectors on the helicals..jyst need to trim
That's awesome another project to add to the listIf you use special clear hardner and vacuum mold or use plexi with pva you dont need to sand ir anything..comes out ready to go.
send me one and ill open it for youI would love to see the insides of the smaller 9db DBS/Itelite panel. Any takers?![]()
question Seb if you added 2 more pucks to that would you think it would help on the 2.4 ghz side?View attachment 54279
Is that even possible or does it deteriorate or crosstalk the signalquestion Seb if you added 2 more pucks to that would you think it would help on the 2.4 ghz side?
in parallel or serial
I'm not entirely sure, I haven't seen inside one of the pucks but my guess is it would mess with the impedance which would probably give you worse signal than before, that's my understanding of it but there's still much to learnquestion Seb if you added 2 more pucks to that would you think it would help on the 2.4 ghz side?
The way I see it the signal is retrieved from the antenna and is still spiraling in a pattern through the cables to the Tx or Rx, so if you had to signals coming into one cable it would seem that once they collide that rhythm would be extremely disruptedI'm not entirely sure, I haven't seen inside one of the pucks but my guess is it would mess with the impedance which would probably give you worse signal than before, that's my understanding of it but there's still much to learn
Here ya go....![]()
Put those away MB! You can't bust those things out it workHere ya go....![]()
