- Joined
- Jun 11, 2015
- Messages
- 645
- Reaction score
- 184
- Age
- 61
? What are you asking? Had one! Sold it a week later.parrot bebop
Yeah that's nice! I'm still waiting to receive the battery backpack for mine. Thanks for posting a picture of it.I like this new backPack, plugs in the Mayday and has an "on-off" switch, as ya see the servo than plugs into the batteryPack (also has a clear case cover now)
No body can guarantee 100% safe recovery of your UAV, too many factors at play here. This Parachute Deployment System in my opinion should help greatly, if installed correct, and you have good altitude. Be sure you read all the "pro" & "con's" before you invest into this system, as it is a little pricey.I lost my P3A Christmas Eve. It was windy, but since I heard about people successfully flying in gusty winds before, I decided to try my luck. I upgraded the firmware just before the flight, and I guess I should have tested the new firmware in calm weather first!! Anyway, I flew in the gusty wind (not sure what the wind speed was). When I first took off, the craft got blown in the direction of the wind right away - the GPS hold wasn't working. However, when I applied the controls to counter the wind, things appeared to be under control. So I got up to 90-something feet and started flying normally. Suddenly, when the craft was just 300-something feet away from me, it tumbled and fell to the ground faster than I could react. (Not sure my reaction would have helped anyway by that point!) Anyway, I'm getting another P3A. I wonder if this one could be protected somewhat by a parachute like the one being discussed in this thread.
You are not alone, I must have done that "over-the-head" trick 20 times, the mayday learned that I was about to throw a fit and finally deployed, if ya do get it to do it's thing it took mine a few minutes to re-set from flashing red led, I had to turn it off then on again.Truth be told I have made well sure update was done correctly and everything is set up as it should be but I haven't been able to get a deployment.
