Lost RC signal at 300 meter?
Off topic question but I don't want to start a topic over it.
Any one know if Australia is FCC or CE? Thanks
Or does it say somewhere in the go app?
my understanding is the P3S uses GPS to locate and switch from FCC mode to CE mode according to location.
Yeah i understand that just don't know where Australia falls
Australia is CE mode, even though neither standard actually applicable here.
I got mine out to just over 400m when I got low signal warning.
Ok thanks. Yeah I managed to get 1600 over water. But I do have an ARGtek antenna
USA/1.6.8 firmware
Reactions: cekabu
USA/1.6.8 firmware
It seems thatyoualso have many trees around but getover 1000 meters. Thats great! I was also able to fly that much but now only 200 meters. I rebind the RC install the dji go app several times make the calibrations but no success
I thort my rc controler was my problem so i purchased a newish rc and the same problem with the drone
I with there was a way to format the drone and install the software as new
Or return p3a to factory settings
Sent from my SM-G920I using Tapatalk
Unfortunately, that's not possible.
You have a P3A, or P3S?
This is a P3S thread, and unsure why you thought your remote was bad range problems or linking problems.
You cannot go do a factory reset, but I do believe you downgrade your firmware on a Adv&Pro.
I'm not surprised. In my neighborhood I get between 300-500m before RTH. Out over a lake she flew over a mile away. (1604m)
