My guess is, you won't see anything there either, unless it is in the ESC/Motor control area as far as the altitude loss goes.When you get it back, look at the on board data for clues.
Already been reviewed with the available data. Stick inputs will have no bearing on anything as far as the mission goes. And there were none.Would be interesting to look at the stick inputs to see if the autopilot was commanding descent.
Yes.., You did take a video of that.quick update. i used a slingshot, some 65lb test fishing line and a 1 1/2 ounce weight and i was able to pull on the branch with the line and get the drone. successful rescue mission !
This is a bit baffling. I do not yet see a reason for the loss of altitude. According to these charts, the aircraft was still in waypoint mode and started loosing altitude. It's hard to say if this was before or after missions end.
Just for the sake of putting this up. Here is your Litchi Flight profile( In Yellow ), with the Actual Flight Profile( In Red ) over layed on top. All smooth until the end. Still baffled about the altitude loss. It makes no sense. Glad you found it.
