Local help
Midway, Ga
Greetings. So I’m in the sav ga area. I have a preowned p3p and have never got the props to move. It’s always “rc signal lost” or “command timed out”. I was wondering if there was a place or another pilot nearby to look over everything and see if it’s the equipment? Also could it not be responding because it’s not been registered? Like I haven’t done anything aside from taking it home and attempting to update the software.. I feel like my mom vs the vcr right now 😭
Reactions: RodPad
Greetings from Birmingham Alabama USA, welcome to the forum! We look forward to hearing from you!
Sounds like you have a defective Phantom 3 pro
Reactions: IANZONE
Reactions: IANZONE and RodPad
What would you suggest?
Welcome to the Forum.
Have you ever seen this drone fly?
To contact others in your area, post in the 'Regional Meetups' section on PhantomPilots and see if someone nearby responds.
In the meantime, checkout 'Phantomhelp.com' Just be sure to select the correct Phantom model (P3P) for any information you need. (Phantomhelp.com is provided by an approved vendor, msinger, here on the forums.)
The indication that 'RC signal lost' sounds like the link between the RC and bird has been lost. Normally an easy fix. Just check out the re-link procedure in the P3P manual (can be downloaded free) or on Phantomhelp.com.
Any other information you could provide about the RC or Drone's actions (Lights, app messages, etc) will help others diagnose the issues.
Reactions: RodPad and IANZONE
Attempting to upgrade , sounds like a fail,what brought you to decide to do that,
As above ,if you can provide more discription it help
Pre- owned and flown or still new unactivated ,more info you can provide is good
Welcome to the forum!
There is a lot good members, that will help you out!
5% has already replied. 👍
There is going to be many questions, your feed back is what is most important.
As mentioned, should look at this link, there is manuals that never came with the product
DJI Phantom 3 Professional Accessories & Tips | Phantom Help
Rod ..
