Lite Foot
Los Angeles
Lite Foot, like many of my projects, began as one thing, but took on a life of its own and ended up being something I didn’t completely anticipate. Simply put, I started out building an ultra-light P3 as another way to achieve extended flight.
Frankly, I wasn’t optimistic about this goal from the start because the Phantom 3 really is a pretty light copter to begin with. This goal came from concluding that DJI had gone to great lengths to design a battery manager that not only could take good care of an HV lipo battery, it could also read more than just its voltage. DJI went to great lengths to design the thing to make sure it could detect the presence of additional battery capacity, and defeat it. Presumably, to maintain control of its product and to make sure aftermarket suppliers could not make it competitive with its future products? It took me a while to come to this conclusion, and I made up plenty of new profanity in the process. I also learned to dislike my new, favorite corp DJI, like I have never disliked a manufacture before. Everything from the way they treat their customers to the underhanded way they implement firmware updates, which can’t be trusted anymore. For something like a drone with safety issues all over the place, this really sucks.
P4? You have to be kidding… (my own personal thing guys, no offense P4 owners – please enjoy) I do like the P3 pro very much and have a significant investment in it. I am either going to continue with it and expand it if it continues to open up, or move to another platform. As hard as I am on DJI, my hat is off to them for the P3 pro. It is the perfect everything. Size, etc… What I have done with my Lite Foot project is an example of how it may be expanded with exotic materials and tele-photo. Call this a P3 compatible. Like a VW bug. The P3 is a pretty big, horizontal success, and my guess is that parts should be available indefinitely.
Back to Lite Foot. Originally it was simply P3- Ultra-Light. I am easily distracted, especially when it is something that may give my project a cool, Indian sounding name. If I stayed strictly true to my theme, I would not have put the cool feet on Lite Foot. They cost a good 50 grams, or so. As I was testing the ultra-light, it became clear this was going to be a work horse. Everything about it wanted to stay in the air. It is so easy to service. Btw, I have learned to lubricate my motors. I didn’t think these sealed bearings needed it, but it makes a huge difference. I actually designed the motor mounts to make this easy. I also provide air vents and use the second version motors. They run slightly warm to the touch (instead of really hot).
The work horse did need good markings to use it easily. This copter is fitted with a Ragecams adapter and takes various different size tele-photo lenses. So, it is often at a distance when run visually. Where to put the LED’s so that they don’t interfere with the camera work? Put them on the feet, of course.
This design uses a modified stock P3 smart battery that is split into two, 2s sections. This facilitates the shorter, vertical profile. It is probably a little lighter since it loses the housing pieces. This shorter vertical height requirement makes it possible to expose less surfaces to the wind, and was the reason for it. Despite its light weight, Lite Foot does not get thrown around very much in the wind.
Oh, so what did I get after all of this? Yeah, I was right, the P3 is hard to beat on the weight, but I did, by about 120 g’s and I don’t need to add a thing. With the standard, single battery, I get a reliable 22-minute flight time as reported from the battery screen (see attachment) This is quiet flight, btw. The noise issue was one of my original motivations that I forgot about, but quickly realized how important it was to me during my testing. This is a quiet bird. My neighbors used to complain, especially when I started doubling up the batteries (they get louder). The 120 g’s make a significant difference. The copter sort of loafs in the air.
Also, as I indicated, I don’t need to add anything. Check out how high the camera is and how wide the stance is. It is a very stable platform for my camera work, far superior to the standard P3 – why(?), dunno. Drives like a 911 without the over-steer.
Now that I have fixture and templates: The next frame is going to be a strict Ultra-Light. The P3 really doesn’t need the LED’s although it does use them for communicating many things. Perhaps I will use very small LED’s, instead of the stock ones, or a fluorescent paint job.
I put a (hard-won) piece of documentation concerning extended flight in a PDF here. I think you guys deserve it. DJI shouldn’t be jerking us around with our own technology. Cheers.
This frame is also meant for serious extended flight, as well and I will do that shortly. Since it will do 22 minutes normal, I have high hopes for the extended form. To go extended I would be giving up quiet flight and performance. Twenty-two minutes is enough for almost everything, but there will be applications where you simply need time in the sky. Extending is a matter of strapping a second set of split 4,480 mah batteries onto the frame rail – the side the name is on.
Totally-Optional Reading:
Just to expand a little bit on what drives my DJI/China venting, and please don’t for a minute, mistake this for anything past corporation or country, I absolutely don’t view ethnicity at all in my vents.
How about this battery manager DJI is so proud of? Sure, it does take care of the battery, and the charging hardware is built into it. The jury is still out on the automatic discharge-to-storage mode. I just haven’t seen it work reliably. Fly your drone and observe the voltage on the transmitter, and eventually have it over-rule pilot based on battery health and land drone. Very impressive.
Impressive until you try to add battery capacity to the vessel and observe the results. The results don’t jump out at you, you have to digest them. But they are there if you are knowledgeable about healthy lipo cell voltages. If you had connected your added capacity in the logical place, where it could be managed by the battery manager switch, what you would be observing on the transmitter would be early alarms that you are running out of battery. At the same time, it would be reporting a nice, green high voltage for each cell.
What I finally realized is that the battery manager is also watching amperage, or motor load. It is not only watching, but if it decides it is high enough to be the weight of more battery it kicks its land-no-matter-what timer in to defeat our attempts to extend the range, cleanly.
As I have documented, this can be defeated by injecting the added current directly ahead of the battery manager, where it doesn’t have a chance to monitor it through its circuitry. There is still the general power to weight physics ratio to contend with, but that is under the users control.
As a side note on this successful extended flight method, since it is un-switched, it is awkward as hell. No one seems to document how to use it properly and one will always be forgetting to plug-in, or un-plug at the right time. Other than that, it seems to work just fine :) ....
Another side note in reference to the above, if a NO (normally-off) relay were put into the assist circuit, energized by the general system power, in theory I believe this would become a no-brainer, and easy to use. One could even set up and plug-in the assist batteries in advance without the bird going live. I’m not sure about the drain of the relay, and if it is worth it. Maybe someone could do the math. The relay could be replaced with a switch (w/led). Obviously I haven’t tried any of this, but will be soon.
OK, as I indicated, it took me a while and a ton of cuss words to get here. As far as I am concerned, if DJI wants to play these games, they are bringing it on themselves. These products of the thousand-year-old civilization (re: philosophy, values..) would probably say it is their right to protect their product and that would be living in a dream world. The reality would be more like DJI giving elaborate reasons of how these things the battery manager are doing are necessary to verify the health of the battery. You know, the DJI spin - total hogwash. OK.
Consider this, however, and this is the reason you wouldn’t find this sort of thing in a domestic product of this nature. These drones are pretty elaborate devices. Things do go wrong sometimes, unexpectedly. To make something as vital as the battery manager unnecessarily complicated, and I mean 10 times as complicated as it needs to be, is ridiculous. I consider it irresponsible. This is a safety issue. DJI has put their future competitiveness ahead of safety.
How many times have you heard of an un-explained drone disappearance? The battery manager has the authority to shut the drone down. It is almost statistically impossible that failure of their proprietary flight time system hasn’t been the cause of many of them. It is the most complicated part of the battery manager.
Do you think DJI fesses up about drone incidents caused by battery manager logic failure. The logic should be only: Is the voltage high enough? That’s all. There is not much that will go wrong with that.
YouTube Link:
phantom4 zoom lens telephoto modification Ragecams inspection Search & rescue wa | HD Wearable Video Custom Mods By RageCams
That is amazing. The lights on the feet are a great idea.
Ha...this is awesome. I've been considering a similar frame swap and you might be pushing me over the edge. Couple questions for you:
Are those carbon legs and are the antennas inside there??
Did you duplicate the funky motor mount angles or flatten them out?
EDIT: and what are you using to lube the motors?
MV,
My hat is off to you, fantastic job! That is one cool looking piece of equipment!
Jerry
Amazing job.
If kits are available to convert, people will start converting to Lite Foot if they crash.
Reactions: cyrusthevirus
Nice job MV
Thanks! Originally, it was named Black Bird II, but as I was doing the feet I thought of Lite Foot :-)
Funny how a little detail like the feet can ripple through a project like this because while it sort of breathed inspiration into this project, the timing was such that for a while I wasn't sure I was going to be able to keep them.
Right after doing the feet I cut the lightening slots in the frame using a high speed Dremel w/ carbide cutter. This generated a lot of very fine carbon fiber dust that infiltrated everything. It was simple enough to clean the circuit boards w/ alcohol, but simply blowing the motors out wasn't enough, I soon learned.
I learned the importance of using a high speed bearing oil from this experience. My tests flights became very erratic, and for a while I was blaming it on the wires powering the LED's in the feet. I thought they were interfering with the antennas adjacent to them. But I was also confused about this because I had already tested this and found no conflict. I did manage to catch a motor acting funny, though, so I focused on them.
Long story short, I thoroughly cleaned the motors and lubed them with the right type of oil, as I do regularly now, and the copter flies better and smoother than ever before.
Lol. I thought your project started from motor mount stress cracks.
If you want to shave more weight off, you should consider removing the legs altogether and design a hand catch grip and use and opened box-like container for take off.
Another option is to use a tri legged rear tilted landing legs. Mount a 135deg L shaped leg mounted behind camera gimbal that doubles as gimbal protector. The 135 degree L would encourange the P3 to tilt back onto 2 smaller stilts under the 2 rear arms. You just need to make the 2 rear stilts tall enough that the props don't cut too much of the lawn but short enough so it doesn't tip foreward.
Affirmative on the legs. Everything I used to fabricate this thing, aside from what needed to be clear, is carbon fiber. And yes, like the stock P3, this one has the antennas dropped down the legs.
Anyone that is comfortable working with fiberglass would be right at home working with carbon fiber. Pretty much the same methods are used to fabricate and epoxy is the favored resin. Machining it can make you feel a little itchy, and black all over :-)
I was thorough about duplicating the P3 motor positions, etc.. I'll attach some pics
Amazing job.
I agree with the concept. The idea of P3 compatible is very appealing to me. I'll bet every component on the P3 is OEM reproducible (and OEM improvable)
Certainly, nothing on my frame is a copy of DJI work.
There is no way I could build something that would provoke the swearing DJI can. That company has nothing to worry about.
There are special oils available for high speed bearings. Go onto Amazon and search for drone motor oil or something like that. You just use a drop, top and bottom every few flights, so go for the best. Get a bottle with a short needle.
Have you noticed any range effects? I remember having a pretty bad time with any RX wire antenna inside a carbon tail boom, but that was the bad ol' days of analog FM. Have kept antennae and carbon as separate as possible since.
Clever jig for the motors. I was going to ask you if you got angle measurements but I'm guessing probably not
I was more concerned about the LED, power wires. I didn't know about potential issues with the carbon. Ha! - glad I didn't I had enough to worry about. Anyway, I haven't done distance tests yet, specifically. I sort of mimic that sort of challenge in other ways by bird in basement, transmitter in garage. I know where things should be. Well, actually, I guess, I did take it to the ceiling (accidentally) with no problems. I was changing from metric to imperial, and for some reason, it shot to the ceiling. I don't consider that much of a test, though. A real test needs to be straight, for miles... I have a transmitter made for this.
My hopes are that I have improved the signal because of the separation I have given the antennas. The separation from each other, and the distance from the ESC board. I hope the carbon doesn't hinder the antennas. There is a lightening slot cut that exposes the antenna on the inside of the leg that might help compensate for this.
Keep your experiment going on. Best wishes.
I found out the hard way that the RC receivers for helis needed to be mounted with the antennas well outside the CF frame otherwise range was severely limited.
