- Joined
- Oct 30, 2016
- Messages
- 25
- Reaction score
- 11
- Age
- 41
Hello Pilots,
P3P user here. I'm new to Litchi and haven't used it out in the field yet. I want to plan the missions very carefully (leaving lots of extra altitude in different terrains, always going above trees, and open fields, etc) but based on past experience, the video feed will stop working during the mission because of its limited range. My question is regarding this situation:
1) Will the gimbal pitch change if I set it manually for the waypoints with interpolate? I have seen some discussions which suggest that the camera will not be changed if the RC is out of range. The official documentation doesn't mention this, or at least I haven't seen it. I do however recall seeing some posts claiming that it still worked. I would like to get a definite on this.
2) The help says this about the speed: "This setting is only in effect when the aircraft is in range of the remote controller. If signal is lost during the mission, the aircraft will continue the mission at the speed it was travelling at when it lost signal."
I'm just done planning a bunch of missions that were all along the lines of "go to this remote place, circle it slowly, come back". Without knowing or understanding the above warning, the drone would have certainly drained the battery while trying to return at say 2km/h.
This is a real buzzkill to be honest. Is this a Litchi limitation? Is it the Phantom's limitation? Does the SDK not allow for Litchi to program the specific speeds into the mission? Is there any chance for this to change? Will it be possible with the Mavic?
Thanks in advance for any clarification on this.
