Litchi Way-points Help Please
Smithfield RI
Hi all New to the forum but have been flying for a over a year now. Tried Litchi way-points for the first time last night. Started in P mode to make sure the compass was calibrated then moved to F mode and flew up close to my first way-points altitude. I then engaged the mission with out issue. ( This mission will take the unit out of radio contact but was confident based on all that I read that it would finish the mission). first way-point was a success and then the signal started to drop and I did not panic as the GPS map still showed the unit moving toward the destination. after about 30-40 sec's of no signal of picture I walked up m,y stairs a bit and the image popped back on with a weak signal. The unit was now hovering after but not RTH or completing the mission. So i jumped in the car and drove over to where the last image I saw was. Long story short i got the unit back after it auto landed it self from a low battery and driving around looking in peoples yards.
I do not recall pressing anything or changing anything after the signal loss, i am wondering why the unti would not have completed the mission and come home... any thoughts ?
I have flight logs and data in Excel form if anyone wants to take a crack. I am hoping it was glitch as i want to try a long distance mission again.
Thanks
Dan
Check the final action at the last waypoint. Was it set to "Hover"?
Reactions: Pharm
Verify what Fly Dawg said, then try it again. If it repeats, get back to us.
Other thoughts: How far away was the last waypoint? What was the setting for the final action (via Fly Dawg's question)? I always set my first waypoint close to me, then set my final action to "return to first waypoint ".
@Pharm Putting the last waypoint close to you works too!;)
Reactions: Pharm
Check the final action at the last way-point. Was it set to "Hover"?
Thanks for replying... the final action at the last way-point was set to back to first waypoint. This should have been after the mission and when it returned home though.. thoughts ?
The last way-point was set like 4 feet from the first so the unit would have flown a full "loop"
4 Feet? If I am not mistaken, waypoints cannot be that close together. How many waypoints did you have and how were they configured? Generally when something like you stated occurs is a mission planning error.
4 feet, 400 feet, your looking for a crash. :eek:
Link not working for me, make sure its not private, to test if works open the link with another computer or browser not signed in to Litchi.
Rod
Waypoint #2, curve size 953ft??? Error! I think. You should have set the flight for straight lines insted of curves in this scenario.
Also, you are very close to an airport there at waypoint 3 and 4, GEO Fencing maybe?
Reactions: Pharm
Thanks those are good observations. May i ask where you see the curve of 900 feet ? i might be missing it ?
I am going to build a mission via the Hub and post it up... would you mind taking a look and letting me know what you think ?
Waypoint 2 per Mission Hub, look at the curve size.
Reactions: danwchabot
I'm still thinking....got nothing for you yet.
canadiansauna
