Litchi export strange waypoints in my mission
Hi,
If I import a csv file with 2 following way points being at the same lat/lon but with different heading, it seems Litchi create a buggy mission. Look at the 2 two attached pictures and you will see 2 points near the equator !
I can skirt this problem if for exemple I change the later decimal of longitude of one point. I also joined the good and false csv files for the missions.
Any idea ?
Cheers,
FRC
Litchi Version 2.9.1 for iOS
iPad 2
I seem to recall that Litchi doesn't deal with waypoints that are too close together, I've not used it for a while but I remember that changing altitude got around it. Will try when it's next not raining.....
Reactions: Billie Nelson
Ok and thank you for your remark. Tell me when the weather will be better. Here in France I have the same problem. Flying is a pain !
I didn't look at your files but here are the DJI SDK Limits (used by Litchi):
DJI SDK Limits:
Min-Max 3D distance between 2 WPs: 0.6-1999m (2-6561ft)
Max distance between Home and WP: 4000m (2.48mile)
Max Cumulative mission distance: 30000m (18.64mile)
Min-Max Corner radius of waypoint: 0,2-1000m (0.6-3280ft)
Min-Max Orbit Raduis: 15-500m (49-1640ft)
Min-Max WP Height: -200-+500m (-656-+1640ft)
Min-Max POI Height: -200-+500m (-656-+1640ft)
Min-Max Mission Waypoints: 2-99
Max number of actions per waypoint: 15
Max number of times a single waypoint action can be repeated: 15
How many times the ground station task will be repeated: 1-255
Min-Max Pause setting in WP-action: 0-32 sec. (0-32767 ms)
Rotate UAV in WP-action: -180°, +180°
Controllable Gimbal range: (-90° to +30°), -90° to +0°
For Gimbal Pitch changes and Flying Speed Changes to work there MUST be a connection between the AC and RC.
The altitude of the aircraft is relative to the ground at the take-off location, has a range of [-200,500] and should not be larger than the aircraft's max limited altitude. If two adjacent waypoints have different altitudes, then the altitude will gradually change as the aircraft flies between waypoints.
