Litchi: Can't change RTH altitude
Android 7.0, Nvidia Shield K1; P4 powered up, Litchi connected.
The RTH altitude is set to 148 ft in the "Aircraft" section of the settings. No matter what I change it to, when I come back there again to check it it's 148 ft.
Is there a SAVE button somewhere or something? Anyone have any idea what's going on? I want to set it quite a bit higher.
First let's clear up a bit of confusion. RTH is always in meters regardless of which app you are using and which units you have set, just one of the quirks in the DJI programming. So 148 m is over 550 ft. Check on what your maximum height setting is (and double check the units).
Interesting, in litchi you can set either imperial or metric in units but as Richard said, your RTH is always in metres. So your 148 is metres and not feet. Your RTH and Max altitude are mirrored from your dji settings which when adjusted are saved. Try adjusting them in dji first and see what happens.
dlr11164
