lightbridge firmware PROBLEM (and solution) - firmware version not found by dji assistant tool
Hi Everyone,
Ive soldered everything as it says and am trying to flash the image but continue to get BOOT ME (air unit)
Notice Target:curropt
I've tried Win vista 64 bit, 7 32bit and 10 64bit
Ive tried Crtl + C and restart CMD/redo command
To get the "BEGIN" command i have to keep the exe running and reboot the phantom like in the description. However it just changes to "curropt" and goes back to "BOOTME"
Anyone have any ideas? been stuck on this for a long time!
Any luck? I am having the same problem.
When I try to flash LB air unit, I see these messages. Reboot and CTRL + C do not give any results. LB ground unit works after firmware update.
what am I doing wrong? Thanks
Any luck figuring it out? I am having the same issue.
Reactions: mcoaguilar
This curiously matches your log:
Flashing firmware on DaVinci media processors · mefistotelis/phantom-firmware-tools Wiki · GitHub
No image for you is there, though. But you may try the one for Ph3, maybe...
EDIT: Also note the UbiFS flashing description - based on it, if you will try to flash the whole NAND, you willdamage UbiFS.
I'm an owner of Phantom 2 Vision Plus V3.0 for last 4 years - yesterday, after 4 months of long winter with very bad weather conditions, I tried to let bird fly and I experienced unpleasant surprise because of no live video feed, just dark screen with full telemetry data.
Thanks to DJI Phantom 2 Vision+ Plus Blank Screen Corrupt NAND fix I quick fixed WiFi module despite that it was WM301_DM368_V1 model.
So conclusion is that there is no need to looking for Phantom 3 version software - version for old Phantom 2 Vision Plus works for V3.0. I hope it will be helpfull news for someone.
Thanks guys for great work!
Hi Everyone,
Did you find the solution? I have the same problem, try steps 9 and 10 of the first step and also ... do not advance the TARGET: BOOTME
Hello, sorry, I have a problem in my P2V+, I have done all the steps but when I entered the command the screen does not pass from ...
waiting for the DM36x...
Target: BOOTME
BOOTME Command received.returning ACK and header...
ACK command sent. Waiting for BEGIN command
Target: BOOTME
CAN ANYBODY HELP ME? PLEASE
Mabe try to erase NAND first:
sfh_DM36x.exe -nanderase -v -p "COM10"
(insert proper COM number instead of "COM10"
It helped to me.
It helped to me.
thank you for responding, and try to delete the NAND with that command (in my case the assigned port is COM3), try several times with CTRL + C but always stay on the same screen
Many thanks to the topic starter, the method works!
Target: BOOTME
Target: BOOTME
I had the same situation, but with the lightbridge 1 ground station .
I tried to download the firmware using two different USB-Serial adapters that I have.
One from ODROID (blue), the second one bought ftom hobbyking for flight controllers (see photo).
With blue one it was the same as you - utility see BOOTME request but no reaction on ACK from the pacient.
With yellow one everything was immediately started loading and in the end it all worked!
I didn't erase flash.
Blue as far as I know with the levels of 1.8-3.3 V, yellow, i think 3.3-5 V. Maybe the problem is in the adapter (signal levels or something else).
Thanks for the information, I will try another USB adapter and if I succeed, I will gladly share my experience and help anyone who needs it, regards
D
the method works !!!! I am very grateful to all those who have helped me, Gaucho, you are great, Maxe, thank you very much for the advice to change USB Serial adapter, I tell you about my experience: I have a Panthom 2 Vision Plus and had a black screen, I had previously bought a wifi module and with that I started to do tests, I can never make it work, it did not happen BOOTME BOOTME, and I decided to try it with the original module, I did all the steps and immediately I could flash it, now I have an image !!! I have not yet been able to operate the second module, but the important thing is that my P2V + works! thank you
Hello. Same problem with a PV331 (then a PV2+)....
After 1 year without use, i load battery, test it, power on bird, got image, all working.
place in the air (30 cm of the ground, in the garden). after 20 sec, battery self POWEROFF. bird fall in the grass. without break anything.
With second battery, i restart PV2+, and don't get any picture on screen ! i was thinking camera is broken, but when i do picture and look on sd, it's good.
search again and again and discover the "black screen" issue.... and this fantastic page !
i follow the procedure given here :
sfh_DM36x.exe -nandflash -v -p "COM7" dm6467_297_ubl.img u-boot_modifiedByGaucho.img
(success)
then
sfh_DM36x.exe -nandflash -v -p "COM7" ubl1_editedByGaucho.img u-boot_modifiedByGaucho.img
(success)
it boot fine (see captured text below).
but still no live stream (picture/video record correctly on sd)
is it right files for phantom vision 2 + ?
is there any possible other problem ?
if module boot (as see in following captured text), can we say that module is not dead ? not bad ?
heeeeeelppp ! thanks !
[ DM36x initialization passed!
UBL Product Vesion : DJI-GSP-UBL-1.0-rc10(2014-08-15)
Dji UBL Version: 1.51(Aug 15 2014 - 17:05:12)
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
Uboot Checksum:0x7E25B44B
Actua Checksum:0x7E25B44B
U-Boot Product Vesion : DJI-GSP-Uboot-1.0-rc4(2014-07-23)
U-Boot 2010.12-rc2-svn-Dji (Jul 23 2014 - 11:14:40)
Cores: ARM 432 MHz
DDR: 297 MHz
I2C: ready
DRAM: 128 MiB
NAND: 128 MiB
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
*** Warning - bad CRC, using default environment
Net: Ethernet PHY: GENERIC @ 0xff
DaVinci-EMAC
Press ESC to abort autoboot in 1 seconds
Loading from nand0, offset 0x4a0000
** Unknown image type
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Loading from nand0, offset 0x900000
Image Name: Linux-2.6.32.17-davinci1
Created: 2014-04-09 12:21:58 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3823424 Bytes = 3.6 MiB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 80700000 ...
Loading Kernel Image ... OK
OK
Starting kernel ...
[ 0.000000] Kernel Product Vesion : DJI-Kernel-1.0-rc2
[ 0.000000] Linux version 2.6.32.17-davinci1 (root@ubuntu) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #6 PREEMPT Wed Apr 9 05:21:55 PDT 2014
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine: DaVinci DM36x EVM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] DaVinci dm36x_rev1.2 variant 0x8
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pages: 12192
[ 0.000000] Kernel command line: console=ttyS0,115200n8 rw dm365_imp.oper_mode=0 video=davincifb:vid0=0,10K:vid1=0,10K:osd0=1920x1080X16,8100K mem=48MB davinci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=pal ubi.mtd=2,2048 root=ubi0:rootfs rootfstype=ubifs ip=off lpj=1077248
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 48MB = 48MB total
[ 0.000000] Memory: 44784KB available (3456K code, 310K data, 112K init, 0K highmem)
[ 0.000000] SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:245
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop (skipped) preset value.. 215.44 BogoMIPS (lpj=1077248)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] DaVinci: 8 gpio irqs
[ 0.000000] NET: Registered protocol family 16
[ 0.070000] EVM: tvp5146 SD video input
[ 0.130000] bio: create slab <bio-0> at 0
[ 0.130000] DM365 IPIPE initialized in Continuous mode
[ 0.140000] usbcore: registered new interface driver usbfs
[ 0.140000] usbcore: registered new interface driver hub
[ 0.140000] usbcore: registered new device driver usb
[ 0.140000] vpss vpss: dm365_vpss vpss probed
[ 0.140000] vpss vpss: dm365_vpss vpss probe success
[ 0.140000] dm365_afew_hw_init
[ 0.150000] ch0 default output "COMPOSITE", mode "PAL"
[ 0.150000] VPBE Encoder Initialized
[ 0.150000] cfg80211: Using static regulatory domain info
[ 0.150000] cfg80211: Regulatory domain: US
[ 0.150000] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 0.150000] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 0.150000] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.150000] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.150000] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.150000] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.150000] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 0.150000] cfg80211: Calling CRDA for country: US
[ 0.150000] LogicPD encoder initialized
[ 0.150000] Switching to clocksource timer0_1
[ 0.160000] musb_hdrc: version 6.0, cppi-dma, host, debug=0
[ 0.180000] musb_hdrc: USB Host mode controller at fec64000 using DMA, IRQ 12
[ 0.180000] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 0.180000] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[ 0.180000] usb usb1: configuration #1 chosen from 1 choice
[ 0.180000] hub 1-0:1.0: USB hub found
[ 0.180000] hub 1-0:1.0: 1 port detected
[ 0.180000] NET: Registered protocol family 2
[ 0.180000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.180000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.180000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.180000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.180000] TCP reno registered
[ 0.180000] NET: Registered protocol family 1
[ 0.180000] RPC: Registered udp transport module.
[ 0.180000] RPC: Registered tcp transport module.
[ 0.180000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.190000] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.190000] msgmni has been set to 87
[ 0.200000] alg: No test for stdrng (krng)
[ 0.200000] io scheduler noop registered (default)
[ 0.240000] davincifb davincifb.0: dm_osd0_fb: Initial window configuration is invalid.
[ 0.320000] Console: switching to colour frame buffer device 240x67
[ 0.410000] davincifb davincifb.0: dm_osd0_fb: 1920x1080x16@0,0 with framebuffer size 8100KB
[ 0.410000] davincifb davincifb.0: dm_vid0_fb: 0x0x16@0,0 with framebuffer size 10KB
[ 0.410000] davincifb davincifb.0: dm_osd1_fb: 720x576x4@0,0 with framebuffer size 810KB
[ 0.420000] davincifb davincifb.0: dm_vid1_fb: 0x0x16@0,0 with framebuffer size 10KB
[ 0.480000] DM365 IPIPEIF probed
[ 0.480000] imp serializer initialized
[ 0.480000] davinci_previewer initialized
[ 0.490000] davinci_resizer initialized
[ 0.490000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.490000] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
[ 0.950000] console [ttyS0] enabled
[ 0.950000] serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
[ 0.960000] brd: module loaded
[ 0.970000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 128MiB 3,3V 8-bit)
[ 0.980000] Creating 4 MTD partitions on "davinci_nand.0":
[ 0.980000] 0x000000000000-0x0000004a0000 : "bootloader"
[ 0.990000] 0x0000004a0000-0x000000e00000 : "kernel"
[ 1.000000] 0x000000e00000-0x000007f00000 : "filesystem"
[ 1.010000] 0x000000000000-0x000008000000 : "all"
[ 1.020000] davinci_nand davinci_nand.0: controller rev. 2.3
[ 1.030000] UBI: attaching mtd2 to ubi0
[ 1.030000] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 1.040000] UBI: logical eraseblock size: 126976 bytes
[ 1.040000] UBI: smallest flash I/O unit: 2048
[ 1.050000] UBI: sub-page size: 512
[ 1.050000] UBI: VID header offset: 2048 (aligned 2048)
[ 1.060000] UBI: data offset: 4096
[ 1.540000] UBI: attached mtd2 to ubi0
[ 1.550000] UBI: MTD device name: "filesystem"
[ 1.550000] UBI: MTD device size: 113 MiB
[ 1.560000] UBI: number of good PEBs: 904
[ 1.560000] UBI: number of bad PEBs: 0
[ 1.570000] UBI: max. allowed volumes: 128
[ 1.570000] UBI: wear-leveling threshold: 4096
[ 1.580000] UBI: number of internal volumes: 1
[ 1.580000] UBI: number of user volumes: 1
[ 1.590000] UBI: available PEBs: 0
[ 1.590000] UBI: total number of reserved PEBs: 904
[ 1.600000] UBI: number of PEBs reserved for bad PEB handling: 9
[ 1.600000] UBI: max/mean erase counter: 36/1
[ 1.610000] UBI: image sequence number: 930050959
[ 1.610000] UBI: background thread "ubi_bgt0d" started, PID 313
[ 1.620000] console [netcon0] enabled
[ 1.620000] netconsole: network logging started
[ 1.630000] i2c /dev entries driver
[ 1.630000] Linux video capture interface: v2.00
[ 1.640000] vpfe_init
[ 1.640000] vpfe-capture: vpss clock vpss_master enabled
[ 1.650000] vpfe-capture vpfe-capture: v4l2 device registered
[ 1.650000] vpfe-capture vpfe-capture: video device registered
[ 1.700000] EVM: switch to tvp5151 cvbs video input
[ 1.700000] vpfe-capture vpfe-capture: v4l2 sub device tvp5150 registered
[ 1.710000] EVM: switch to it6604 hdmi video input
[ 1.720000] vpfe-capture vpfe-capture: v4l2 sub device cat6023 register fails
[ 1.720000] vpfe_register_ccdc_device: DM365 ISIF
[ 1.730000] DM365 ISIF is registered with vpfe.
[ 1.740000] Trying to register davinci display video device.
[ 1.740000] layer=c1ffa800,layer->video_dev=c1ffa964
[ 1.750000] Trying to register davinci display video device.
[ 1.750000] layer=c1ffac00,layer->video_dev=c1ffad64
[ 1.760000] davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
[ 1.770000] watchdog watchdog: heartbeat 1 sec
[ 1.770000] TCP cubic registered
[ 1.780000] NET: Registered protocol family 17
[ 1.780000] lib80211: common routines for IEEE802.11 drivers
[ 1.790000] Clocks: disable unused mmcsd0
[ 1.790000] Clocks: disable unused mmcsd1
[ 1.790000] Clocks: disable unused spi0
[ 1.790000] Clocks: disable unused spi1
[ 1.790000] Clocks: disable unused spi2
[ 1.790000] Clocks: disable unused spi3
[ 1.790000] Clocks: disable unused spi4
[ 1.790000] Clocks: disable unused pwm0
[ 1.790000] Clocks: disable unused pwm1
[ 1.790000] Clocks: disable unused pwm2
[ 1.790000] Clocks: disable unused pwm3
[ 1.790000] Clocks: disable unused timer1
[ 1.790000] Clocks: disable unused timer3
[ 1.790000] Clocks: disable unused emac
[ 1.790000] Clocks: disable unused voice_codec
[ 1.790000] Clocks: disable unused asp0
[ 1.790000] Clocks: disable unused rto
[ 1.790000] Clocks: disable unused mjcp
[ 1.860000] nnnn===0
[ 1.860000] davinci_emac_probe: using random MAC addr: 8e:84:e3:95:52:9f
[ 1.870000] emac-mii: probed
[ 1.910000] UBIFS: recovery needed
[ 2.010000] UBIFS: recovery completed
[ 2.010000] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 2.010000] UBIFS: file system size: 110342144 bytes (107756 KiB, 105 MiB, 869 LEBs)
[ 2.020000] UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[ 2.030000] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 2.040000] UBIFS: default compressor: lzo
[ 2.040000] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 2.050000] VFS: Mounted root (ubifs filesystem) on device 0:13.
[ 2.050000] Freeing init memory: 112K
Runing /etc/init.d/rcS
/opt/dji/bin/sshenable: line 2: ./eth0config: not found
sulogin: no password entry for root
login[418]: root login on 'ttyS0'
#Process /etc/profile...
root@Dji-Pro:~# [ 7.200000] CMEMK module: built on Nov 27 2013 at 14:02:36
[ 7.200000] Reference Linux version 2.6.32
[ 7.220000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 7.240000] allocated heap buffer 0xc7000000 of size 0x2456000
[ 7.260000] heap fallback enabled - will try heap if pool buffer is not available
[ 7.270000] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 7.280000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[ 7.280000] cmemk initialized
[ 7.310000] IRQK module: built on Nov 27 2013 at 14:02:41
[ 7.330000] Reference Linux version 2.6.32
[ 7.330000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[ 7.350000] irqk initialized
[ 7.400000] EDMAK module: built on Nov 27 2013 at 14:02:45
[ 7.420000] Reference Linux version 2.6.32
[ 7.420000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
pdi=446
Encode demo started.
pdi=0
[ 7.600000] UBIFS error (pid 445): ubifs_read_node: bad node type (255 but expected 1)
[ 7.610000] UBIFS error (pid 445): ubifs_read_node: bad node at LEB 35:90040
[ 7.610000] UBIFS error (pid 445): do_readpage: cannot read page 100 of inode 236, error -22
[ 7.620000] UBIFS error (pid 445): ubifs_read_node: bad node type (255 but expected 1)
[ 7.630000] UBIFS error (pid 445): ubifs_read_node: bad node at LEB 35:90040
[ 7.640000] UBIFS error (pid 445): do_readpage: cannot read page 100 of inode 236, error -22
listening.*********************************************************************** pid of Xorg :-1 ==-1
*************************************************************************************************************killall: encode: no process killed
[ 9.700000] cmemk unregistered
[ 9.770000] irqk unregistered
root@Dji-Pro:~# [ 11.000000] CMEMK module: built on Nov 27 2013 at 14:02:36
[ 11.000000] Reference Linux version 2.6.32
[ 11.020000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 11.040000] allocated heap buffer 0xc7000000 of size 0x2456000
[ 11.060000] heap fallback enabled - will try heap if pool buffer is not available
[ 11.070000] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 11.080000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[ 11.090000] cmemk initialized
[ 11.110000] IRQK module: built on Nov 27 2013 at 14:02:41
[ 11.130000] Reference Linux version 2.6.32
[ 11.130000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[ 11.150000] irqk initialized
[ 11.210000] EDMAK module: built on Nov 27 2013 at 14:02:45
[ 11.210000] Reference Linux version 2.6.32
[ 11.220000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
pdi=489
[ 11.320000] UBIFS error (pid 488): ubifs_read_node: bad node type (255 but expected 1)
[ 11.320000] UBIFS error (pid 488): ubifs_read_node: bad node at LEB 35:90040
[ 11.330000] UBIFS error (pid 488): do_readpage: cannot read page 100 of inode 236, error -22
pdi=0
listening.******************************************************************************************* pid of Xorg :-1 ==446
[ 13.480000] cmemk unregistered
[ 13.530000] irqk unregistered
[ 14.750000] CMEMK module: built on Nov 27 2013 at 14:02:36
[ 14.770000] Reference Linux version 2.6.32
[ 14.770000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 14.790000] allocated heap buffer 0xc7000000 of size 0x2456000
[ 14.820000] heap fallback enabled - will try heap if pool buffer is not available
[ 14.820000] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 14.830000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[ 14.840000] cmemk initialized
[ 14.870000] IRQK module: built on Nov 27 2013 at 14:02:41
[ 14.870000] Reference Linux version 2.6.32
[ 14.890000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[ 14.910000] irqk initialized
[ 14.950000] EDMAK module: built on Nov 27 2013 at 14:02:45
[ 14.970000] Reference Linux version 2.6.32
[ 14.970000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
pdi=0
pdi=531
[ 15.080000] UBIFS error (pid 530): ubifs_read_node: bad node type (255 but expected 1)
[ 15.090000] UBIFS error (pid 530): ubifs_read_node: bad node at LEB 35:90040
[ 15.090000] UBIFS error (pid 530): do_readpage: cannot read page 100 of inode 236, error -22
listening.****************************************************************************************** pid of Xorg :-1 ==489
[ 17.220000] cmemk unregistered
[ 17.270000] irqk unregistered
[ 18.510000] CMEMK module: built on Nov 27 2013 at 14:02:36
[ 18.510000] Reference Linux version 2.6.32
[ 18.530000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 18.550000] allocated heap buffer 0xc7000000 of size 0x2456000
[ 18.570000] heap fallback enabled - will try heap if pool buffer is not available
[ 18.580000] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 18.590000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[ 18.600000] cmemk initialized
[ 18.620000] IRQK module: built on Nov 27 2013 at 14:02:41
[ 18.640000] Reference Linux version 2.6.32
[ 18.640000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[ 18.660000] irqk initialized
[ 18.710000] EDMAK module: built on Nov 27 2013 at 14:02:45
[ 18.710000] Reference Linux version 2.6.32
[ 18.730000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
pdi=573
pdi=0
[ 18.850000] UBIFS error (pid 572): ubifs_read_node: bad node type (255 but expected 1)
[ 18.850000] UBIFS error (pid 572): ubifs_read_node: bad node at LEB 35:90040
[ 18.860000] UBIFS error (pid 572): do_readpage: cannot read page 100 of inode 236, error -22
listening.******************************************************************************************* pid of Xorg :-1 ==531
[ 20.990000] cmemk unregistered
[ 21.030000] irqk unregistered
[ 22.260000] CMEMK module: built on Nov 27 2013 at 14:02:36
[ 22.280000] Reference Linux version 2.6.32
[ 22.280000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 22.300000] allocated heap buffer 0xc7000000 of size 0x2456000
[ 22.330000] heap fallback enabled - will try heap if pool buffer is not available
[ 22.330000] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 22.350000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[ 22.350000] cmemk initialized
[ 22.380000] IRQK module: built on Nov 27 2013 at 14:02:41
[ 22.400000] Reference Linux version 2.6.32
[ 22.400000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[ 22.420000] irqk initialized
[ 22.470000] EDMAK module: built on Nov 27 2013 at 14:02:45
[ 22.470000] Reference Linux version 2.6.32
[ 22.490000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
pdi=615
[ 22.580000] UBIFS error (pid 614): ubifs_read_node: bad node type (255 but expected 1)
[ 22.590000] UBIFS error (pid 614): ubifs_read_node: bad node at LEB 35:90040
[ 22.600000] UBIFS error (pid 614): do_readpage: cannot read page 100 of inode 236, error -22
pdi=0
listening.******************************************************************************************* pid of Xorg :-1 ==573
Code:
OK
Starting kernel ...
Primary kernel is damaged, you're booting from recovery kernel.
You need to flash primary kernel.
Here is how to do it on Phantom 3 Pro:
o-gs/dji-firmware-tools
Thanks a lot for your answer.... Is it the same procedure for Phantom 2 + (as mine ) ?
And where to find correct kernel image file ???
I found "uimage" on this forum in a post "extacted"... the internal binary contain same text as show on working_pv2+_wifi_module : "Linux-2.6.32.17-davinci1"....
But file is 4Mb and capture talk about 3.6Mib...
it's probably the kernel image for lightbridge.... can i use on PV2+ Wifi module ???
