- Joined
- Mar 13, 2015
- Messages
- 1,065
- Reaction score
- 309
That is not necessarily true. I do it and never had a problem.
You're on borrowed time my friend.
Nope,I have been flying and building quads for years...
Well it looks like I've dodged bullets. My last few flights have been on part used batteries at about 60%.Love how it took the OP so long to admit he flew it on a half depleted battery.. This discussion could've been solved in 5 posts. Instead, Everyone chimes in with the blame game; it's the app update, it's the firmware, DJI sucks, etc etc. Nope, it's the pilot. As usual.
And of course the OP "is getting an Inspire 1 now." Lmao. Yeah sure you are.
The biggest issue is not the battery charge per se - it is the combination of a low charge and the time the battery has sat around trying to be 'intelligent'. It appears that the P3 gets confused at times an thinks a partially discharged battery has more power left than it really has. Unfortunately, you're in the air when the voltage goes critical (as in the OP's case) and then you're rapidly not in the air.Well it looks like I've dodged bullets. My last few flights have been on part used batteries at about 60%.
What he said ref the inspire. To true.The biggest issue is not the battery charge per se - it is the combination of a low charge and the time the battery has sat around trying to be 'intelligent'. It appears that the P3 gets confused at times an thinks a partially discharged battery has more power left than it really has. Unfortunately, you're in the air when the voltage goes critical (as in the OP's case) and then you're rapidly not in the air.
The OP was courting disaster when he hit the door. Going out over a beach with a low battery is going to get you in a number of ways. The aformentioned confused battery and a good wind pushing the bird out when you're trying to fly back in. Plop.
And I strongly agree with the other posters concerning the Inspire. Yes, they're very nice. They can even be had at a good price these days. But if losing a Phantom causes rending of garments and gnashing of teeth, think about what crashing out the bigger UAV is going to do to your budget. The low end Inspires don't have a better camera. They don't have better flight times. They can handle winds better - although I've flown the P3 in 30 mph winds, got some great video and lived to tell the tale. They're bigger and harder to haul around. Batteries are expensive.
Yes, they're cool looking. But once it's a couple hundred feet in the air you can't see it anyway.
Yes the fail safes have worked for me in every instance thus far. I frequently fly out of sight living in a densely treed area on the top of a mountain, and get nervous when I lose video feed. Maybe I am becoming a bit paranoid since I don't want to lose my quad and keep reading posts of people reporting strange happeningsThe fail safes still work without video feed.
I have try to charge but it's not charging...maybe need to be less than 90% ..... I have a battery that is at 92% then refuse to charge!If your battery is 80% power, do not fly. Charge first. Then fly.
There is no risk of damage to your battery.
Yes, it's true that you'd "probably" be alright with 80% battery, but do you want to take that risk when it's not necessary? Just charge the battery and fly happily.
Edit: You can read more about this here: Fell Out of Sky - Total Loss
I agree. OP is learning as we all are. None of us was an expert to start and most of us still are not. Keep learning OP, and keep flying.I would not be too harsh with the OP. Yeah it was an error, but it's a really easy mistake to make when you're new. Logically, if you have 50% charge, you should be fine. But the fact is, the manual says always launch on a fully charged battery.
When I was a n00B, I flew a couple times on a partially charged battery and it was fine. I learned of the dangers later reading this forum.
A few weeks ago I thought my lights were acting funny, I had a few minutes the next day, so I grabbed a battery with two solid lights on it and hovered my aircraft at about 8 feet. I didn't even bother with the mobile device or the app since I was only going to hover for a minute or two. As I watched the lights, I noticed the battery went from two lamps on to one lamp on and one blinking. No problem. About 20 secs later the back lights are flashing red rapidly. I brought the craft closer to see the battery lights, and now it was down to only one lamp blinking! Next thing I know the aircraft is landing itself hard on uneven ground. So it tipped over on a hard landing.
My mistake and it was a mistake I already knew not to make: Don't fly on a partially charged battery.
