- Joined
- Mar 5, 2016
- Messages
- 1,039
- Reaction score
- 289
- Age
- 56
I forgot one thing. You also need a 4 sets of lmr-240 or two will work if you connect the amps directly to the lmr-400. Use 2 runs of lmr-240 from the amps to the remote as it is smaller and flexable. Mine is setup to where the lmr-400 comes out the wall in my office and plug right into my amps then from the amps to the remote I used 8ft lmr-240 extensions. Those amps they sell are good and I don't know of anything better. I do have one 5watt I use on my video and 3watt on control. Both 5watt did not work for me at the same time. You don't need more power. This set up in my car with 3watts gets me 7 miles on the matrice 100 but need to do some mods to get any further. I think with the lmr 240 u want one end sma and one rpsma. When I ordered I bought several adapters sma to rpsma vise versa. Best to order it right without using any adapters
Ok cool, so then the Sunhans 3w are the ones the get? Do you have different amps then? For the car and home? I was at Amazon when you replied. It seems I could save a little and get 100' and cut them in half, unless you think that's not wise?
Thanks for all the time man, but there will be others using this info, so it's a big help to all.
I'm thinking after all is said and done, with $160 in amps, and another $160 in cables, you prolly are over $500 with the nice antennas you bought. That's why I ask about the amps, if they could be taken out of the loop to be used for the TX when Mobil.
