Issues with Litchi App lately?
Buffalo, New York
Has anyone else that uses the Litchi app having connection problems with it? It always seemed to work great, but lately in the middle of flying a mission, it'll give the " warning disconnected " error even though i'm full strength on everything. However, it'll continue to fly the mission and record all the same. It's not real comforting . Thoughts on this?
I doubt you are getting "warning disconnected" with five bars on both control and FPV. What might help is to record what is happening on your app so that you can replay it later and study it without being distracted.
If you become disconnected, it will always continue the mission. It's programmed to continue the mission. If it did something else, that is what should be a cause of concern.
I will do that. Maybe there was a split second i missed. But i do know that when it says that, i look down and its fully connected while displaying the disconnected banner at the top. The only way i got that to go away was to land and restart everything. I assumed it was where i was flying, until it happened again. And then a friend of mine said the same thing was happening to him. But I will give the screen record a shot .
I get that message on almost all Litchi missions after a minute or so into the flight regardless of connectivity. The first time was frightful. I now ignore it and let the mission run. Just be sure it's the standard operating bug you're experiencing and not something more sinister before ignoring.
Same here. Says disconnected when clearly I am not. The only way it goes away is landing and taking off again. No other issues so I've just never worried about it
It's a DJI issue, not a Litchi issue. I don't get "disconnected", I sometimes get "Mission Ended" when it hasn't ended. It always completes the mission anyway. I talked to Litchi about this and this was their response:
"The "mission ended" voice may sometimes be heard when signal is lost, please disregard it when it happens, it is a known issue which we hope DJI will fix."
Reactions: cfd701
Sounds like a glitch on the latest app update. l haven't used it lately so l can't concur
Which version did you guys using? Mine is 1.10.1 and its fine. I saw in app store the latest is 1.10.2, not going to update yet.
My litchi won't load on my iPad now after latest update. Have to use the go app
Sent from my Nexus 5X using PhantomPilots mobile app
Works for me at home, didn't in the field.
It would load first time but then if I quit the app then every time after I tried loading litchi the program would quickly close and wouldn't connect even after disconnecting wifi
I read that if you are doing an orbit and lose connection that it will continue to orbit until critical battery levels and then land. Do you know if you can recover by flipping to the P mode ??
If you lose connection, then the AC isn't going to "hear" anything you do with the controller including flipping to P mode.
Reactions: Pharm
Well here’s a thought... did all this start after the last universal update to the bios and DJI Go app? I know that Litchi uses the DJI API so perhaps the base code that DJI supplies has that same issue that is causing the “mobile device CPU fully loaded” issue that has degraded the DJI Go performance.
Same problem here. I hear disconnected message, after few seconds it reconnects, but the video feed is from before it loss connection, so I get lag in seconds. Camera button also lags in seconds. Found out it's a phone problem, cpu is overloaded, can't keep up.
Yes, that would correspond with the DJI latest programming. Bet they did code it into the API
Be sure to look at the date of the post(s) in question. This thread ended in September 2016 so the information contained here may or may NOT be valid/accurate any more.
jeetbuzz360
