Phantom 4 camera won't connect with Litchi app
Flew 3 weeks ago and Litchi worked fine. Camera and drone work fine with DJI apps. Litchi app says controller not connect but I can start the drone up. I know Litchi did an upgrade in Early October so I think that is the issue just wondering if anyone else is having issues with Litchi?
sometimes you may need to disconnect the OTG cable, re-insert it into the controller and see if the app connects
On Android you can NOT simply switch between DJI GO4 and Litchi on the smart device, a disconnect error message will be the result.
You have to force close the active app first, then either restart your RC or disconnect and reconnect the cable between the smart device and the RC, then select the app you want to use to fly.
