Issues with Litchi App lately?
Discussion in 'Standard' started by Jack Barone, Aug 14, 2016.
  1. Jack Barone
    Buffalo, New York
    Has anyone else that uses the Litchi app having connection problems with it? It always seemed to work great, but lately in the middle of flying a mission, it'll give the " warning disconnected " error even though i'm full strength on everything. However, it'll continue to fly the mission and record all the same. It's not real comforting . Thoughts on this?
  2. Mark The Droner
    I doubt you are getting "warning disconnected" with five bars on both control and FPV. What might help is to record what is happening on your app so that you can replay it later and study it without being distracted.
    If you become disconnected, it will always continue the mission. It's programmed to continue the mission. If it did something else, that is what should be a cause of concern.
  3. Jack Barone
    Buffalo, New York
    I will do that. Maybe there was a split second i missed. But i do know that when it says that, i look down and its fully connected while displaying the disconnected banner at the top. The only way i got that to go away was to land and restart everything. I assumed it was where i was flying, until it happened again. And then a friend of mine said the same thing was happening to him. But I will give the screen record a shot .
  4. Flatwoods
    I get that message on almost all Litchi missions after a minute or so into the flight regardless of connectivity. The first time was frightful. I now ignore it and let the mission run. Just be sure it's the standard operating bug you're experiencing and not something more sinister before ignoring.
  5. No_Fly_Zone
    Same here. Says disconnected when clearly I am not. The only way it goes away is landing and taking off again. No other issues so I've just never worried about it
  6. Pharm
    It's a DJI issue, not a Litchi issue. I don't get "disconnected", I sometimes get "Mission Ended" when it hasn't ended. It always completes the mission anyway. I talked to Litchi about this and this was their response:
    "The "mission ended" voice may sometimes be heard when signal is lost, please disregard it when it happens, it is a known issue which we hope DJI will fix."
    cfd701 likes this.
  7. Ohiowoodsman
    USA
    Sounds like a glitch on the latest app update. l haven't used it lately so l can't concur
  8. Jack Barone
    Buffalo, New York
    Thats kind of what i thought. I haven't had a problem with it until the update last week
    gvsukids likes this.
  9. gvsukids
    My litchi won't load on my iPad now after latest update. Have to use the go app
    Sent from my Nexus 5X using PhantomPilots mobile app
  10. FlashBuddy
    Fort Collins, CO
    Noooooo! I just bought an iPad.
    NoCo Drones
  11. Pharm
    Don't panic. Latest Litchi update works fine on my Ipad Mini 2.
  12. gvsukids
    Works for me at home, didn't in the field.
  13. jeganx
    Which version did you guys using? Mine is 1.10.1 and its fine. I saw in app store the latest is 1.10.2, not going to update yet.
  14. gvsukids
    It would load first time but then if I quit the app then every time after I tried loading litchi the program would quickly close and wouldn't connect even after disconnecting wifi
  15. SamC
    I read that if you are doing an orbit and lose connection that it will continue to orbit until critical battery levels and then land. Do you know if you can recover by flipping to the P mode ??
  16. Mark The Droner
    If you lose connection, then the AC isn't going to "hear" anything you do with the controller including flipping to P mode.
    Pharm likes this.
  17. Allen B
    Well here’s a thought... did all this start after the last universal update to the bios and DJI Go app? I know that Litchi uses the DJI API so perhaps the base code that DJI supplies has that same issue that is causing the “mobile device CPU fully loaded” issue that has degraded the DJI Go performance.
  18. sanel_net
    Bosnia and Hercegovina
    Same problem here. I hear disconnected message, after few seconds it reconnects, but the video feed is from before it loss connection, so I get lag in seconds. Camera button also lags in seconds. Found out it's a phone problem, cpu is overloaded, can't keep up.
  19. Allen B
    Yes, that would correspond with the DJI latest programming. Bet they did code it into the API
  20. BigAl07
    BigAl07 Moderator
    Staff Member
    Western North Carolina
    Be sure to look at the date of the post(s) in question. This thread ended in September 2016 so the information contained here may or may NOT be valid/accurate any more.
Similar Threads - Issues Litchi App Forum Date
bought Litchi due to GO 4 app issues Control (Go, Litchi, etc..) Nov 3, 2017
Any Issues with the Litchi App with two or more P3S? Standard Dec 25, 2016
Litchi Issues Control (Go, Litchi, etc..) Jan 11, 2018
Litchi - multiple issues Control (Go, Litchi, etc..) Dec 9, 2017
Litchi Speed Issues ? Control (Go, Litchi, etc..) Sep 6, 2017
