iPhone 5s / iPad Air lag
Hi guys, currently on my 7th flight I am borrowing friend's iPad Air (5th generation) and it works OK with a slight little lag. I also have iPhone 5s and find the same if not worse lag. (+the screen is small)
I am thinking of purchasing a device that would have no lag at all, I have heard really good things about the Nexus 7 - does it have no lag whatsoever? If not what Apple tablet would be the best?
Kind regards
T
Try these tweaks. I setup my iPad Mini 2 using those settings and am seeing no lag. The iPad Mini 2 and iPad Air have the same processor, so you should see similar results.
If you want a faster device, check out the iPad Air 2 or iPad Mini 4.
I think the general consensus is iPad Air 2 Cellular.
That was where I landed. ;-)
Been a very comfortable companion to travel and fly with.
Definitely suggest adding an Inspire 1 device holder, or a similar radio upgrade. The stock holder is a bit on the wobbly side, even after tightening it down. YMMV but it's well worth the slight CO$T.
Set it and forget it. ;-)
RedHotPoker
Reactions: brianb87
jeetbuzz360
