Ipad Air on AT&T cellphone
This is a newbie question(I have flown an P2V+ from a Friend... just got a P3P) :
My Ipad Air is AT&T (LTE) enabled. Should I shutdown the cellphone capabilities?
Has anyone used the LTE capabilities for live streaming using the Ipad data link?
You don't have to shutdown cellular.
I don't know about your other question, I have not used those functions.
Well, if you want to stream to youtube, you need some kind of connectivity.
I have streamed to youtube using an iPad Air 2 with AT&T LTE and also with the same iPad connected to my iPhone as an hotspot. I have bad signal where I live to the quality was not that great. I did notice that when I was streaming to youtube, the distance that I could travel in the phantom before losing signal was greatly impacted.
That's gotta be pretty hard on the data plan?
I use ipad air 2 on at&t. I youtube stream also not problems. Definitely keep cellular data in for map caching and what not. I'll check my data usage and see what's it's used. Basically a dedicated tablet just for the p3
I just flew 6000+ feet with the iPad on Airplane mode and had no signal problems whatsoever. I then landed it, took it off airplane mode and started having signal issues around 2000 feet out. The route was slightly different so that could be why. I will test it again tomorrow, but taking the same route that I did when I was on airplane mode.
Fimaj
