IMU recalibration failure at 2%
Hi, I have had a Minor crash from about 3 foot, now the drone will not fly and is saying I need to recalibrate the IMU, having had a look through the other posts I have now tried chilling the drone for 25 mins outside ( 4 degrees) and even tried the slapping on the battery, I am really worried now, any help ? Thank you , Col
Does it stick on 2% forever and not finally complete? May take quite awhile to complete. leave it to it's work and see if it finally completes. Remember to use a perfectly level surface (use a bubble level) And don't allow any vibration to interfere. Calibrate away from metal objects too.
I think you know calibration procedures. If it fails at 2%, there is a serious issue, you may have to look on the main board for any disconnection.
You say you slapped the battery... I have read of the slapping method, but the battery is not the problem, the problem lies within the drone... so slap the drone.... And try heating it up to above 90 F to see if that unsticks it...
Your IMU is stuck (or maybe the onboard SD card is corrupt).
Can you go to your sensor tab and see if you have any accelerometer/gyro value that is stuck (usually +-16).
If it is stuck, then take a shoe and smack the phantom until the values start moving again. Then redo the IMU calibration.
Errrr, that would be a soft shoe....
Gone through drone doctor£127 lighter but my drone Is now fixed , apparently the IMU was badly damaged could be all the self help I tried, thank you for all the advice
Reactions: Numone
Reactions: crash1sttime
shimuafeni fredrik
