- Joined
- Nov 27, 2015
- Messages
- 755
- Reaction score
- 225
- Age
- 64
My 2 cents: Sorry if any of it has already been written.
I believe that the reason for having two separate activations for OA, primary menu location and the other being in the advanced settings menu, is because they operate independently of each other. This gives the pilot the option to fly the AC with or without the use of OA, while still having OA active for the Failsafe RTH. That said, I think many would agree that it could be all under one menu, but because it is about the Failsafe RTH, I guess it makes sense.
Regarding testing if the AC will come straight home or back up, it will only happen upon signal loss, thus the only way to test this is to block the signal or turnoff the RC.
Here is what the manual says about Failsafe RTH. It is not perfectly written, but I think it does an okay job of explaining how it works.
"Failsafe RTH
The Forward Vision System allows the aircraft to create a real-time map of its ight route as it ies. If the Home Point was successfully recorded and the compass is functioning normally, Failsafe RTH will be automatically activated if the remote controller signal is lost for more than three seconds. The aircraft will plan its return route and retrace its original ight route home. The aircraft will hover for 10 seconds at its current location. When it regains signal connection it will wait for pilot commands. The Return-to- Home process may be interrupted and the pilot given control of the aircraft if the remote controller signal connection is re-established."
"Failsafe RTH
