I bricked my p3s with ftp range mod - let's fix it together
OK, so it sounds like FTP is not an issue. Must be the editing process... Just use text editor, not wordpad...
I used nano on Mac OS El Capitan through terminal and still got the same outcome, I believe it's a mixture of many things
I also used Nano but on Ubuntu linux. Works just fine. I did it about few dozen of times since I discovered the hole. Never failed.
Interesting. Would you mind confirming that it's definetely Nano and not the FTP client ?
I can't duplicate this problem. Never had a single ^M.
Ok, input the comands and i connect to rc with filezilla and.... my rcs its original!! Without changes... why?? And now what to do? Soldering to de gimbal and same, only input comands and my rcs revert to original same in the rc? Thanks and sorry
I had the same issues a lot of corrupted characters, I found it was UART I , I found 3rd UART fixed the issues
Detailed step by step to restore the remote control instruction standard phantom 3 after an unsuccessful modification file rcS
Reactions: Alejandrobs
Dude, stop taking credit for other peoples' work. You need to link to the thread in the description of your video at the very least, and thank those who discovered the fix in the first place!
Reactions: paulgun
Hi already susces connect with tom help. But after pres esc and input script like 1 page. Afer inpit frist and input the
Bootm after that just no result just say reboot and always repet.
Sent from my SM-N9005 using PhantomPilots mobile app
Would you be able to copy the output and paste it in a code block here so that I can read the error messages more easily?
Hello, whats commands tan this
cd /tmp/flash/ && rm -rf ./etc/init.d/rcS && cp -r /etc/init.d/rcS ./etc/init.d/ && chmod +x ./etc/init.d/rcS
TO repair de djiled.sh? i restored de rcs with this command but my djiled i changed to mod... and now not can repair the drone
this the error
ar7240> setenv bootargs board=DJI-WM305 console=ttyS0,115200
ar7240> root=/dev/mtdblock5 init=/sbin/init mtdparts=athnor0:256k@0k(u-boot),64k@256k(u-bootenv),896k@320k(kernel1),3008k@1216k(rootfs1),896k@4224k(kernel2),3008k@5120k(rootfs2),64k@8128k(art),3904k@320k(firmware1),3904k@4224k(firmware2),8192k@0k(all)
ar7240> bootm 0x9f420000
## Booting image at 9f420000 ...
Image Name: MIPS OpenWrt Linux-3.10.49
Created: 2015-12-01 9:06:21 UTC
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 905249 Bytes = 884 kB
Load Address: 80060000
Entry Point: 80060000
Verifying Checksum at 0x9f420040 ...OK
Uncompressing Kernel Image ... OK
Starting kernel ...
[ 0.000000] Linux version 3.10.49 (yello@ubuntu) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r2635) ) #1 Tue Dec 1 17:06:15 CST 2015
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 0001974c (MIPS 74Kc)
[ 0.000000] SoC: Atheros AR9342 rev 2
[ 0.000000] Clocks: CPU:560.000MHz, DDR:450.000MHz, AHB:225.000MHz, Ref:40.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 02000000 @ 00000000 (usable)
[ 0.000000] User-defined physical RAM map:
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x00000000-0x01ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00000000-0x01ffffff]
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: board=DJI-WM305 console=ttyS0,115200 mem=32M rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 29180k/32768k available (2102k kernel code, 3588k reserved, 363k data, 220k init, 0k highmem)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.000000] Calibrating delay loop... 278.93 BogoMIPS (lpj=1394688)
[ 0.070000] pid_max: default: 32768 minimum: 301
[ 0.070000] Mount-cache hash table entries: 512
[ 0.080000] NET: Registered protocol family 16
[ 0.080000] MIPS: machine is DJI WM305
[ 0.290000] ath_usb_init: id: 1122
[ 0.360000] bio: create slab <bio-0> at 0
[ 0.360000] Switching to clocksource MIPS
[ 0.370000] NET: Registered protocol family 2
[ 0.370000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.380000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.390000] TCP: Hash tables configured (established 512 bind 512)
[ 0.390000] TCP: reno registered
[ 0.390000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.400000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.410000] NET: Registered protocol family 1
[ 0.430000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.430000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.440000] msgmni has been set to 56
[ 0.450000] io scheduler noop registered
[ 0.450000] io scheduler deadline registered (default)
[ 0.460000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 0.480000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
[ 0.490000] console [ttyS0] enabled, bootconsole disabled
[ 0.500000] ar934x-hs-uart.0: ttyATH0 at MMIO 0x18500000 (irq = 14) is a AR934X UART
[ 0.510000] ath79-spi ath79-spi: master is unqueued, this is deprecated
[ 0.520000] m25p80 spi0.0: found s25fl064k, expected m25p80
[ 0.520000] m25p80 spi0.0: s25fl064k (8192 Kbytes)
[ 0.530000] g_ether gadget: using random self ethernet address
[ 0.540000] g_ether gadget: using random host ethernet address
[ 0.540000] usb0: MAC d6:2f:09:9d:77:02
[ 0.550000] usb0: HOST MAC e6:00:d4:c7:90:d5
[ 0.550000] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[ 0.560000] g_ether gadget: g_ether ready
[ 0.570000] TCP: cubic registered
[ 0.570000] NET: Registered protocol family 17
[ 0.570000] 8021q: 802.1Q VLAN Support v1.8
[ 0.580000] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
[ 0.590000] Please append a correct "root=" boot option; here are the available partitions:
[ 0.600000] 1f00 8192 mtdblock0 (driver?)
[ 0.600000] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
OKKKKKKKKKKKK MY DRONE AND MY RC ITS OKKK GOOOOD THANKS FOR ALL :)
But... Recomend reTray de range mod or no? please tell me?
So anybody could you help to me?
I have P34K same problem like in group in remote soldered to SN in and out.
In copter soldered to U3_Tx and U3_Rx and GND but puffy cannot read from them...Probadly soldered to bad out anybody could write me step in 4K situation?
Code:
cd /tmp/flash/ && rm -rf ./sbin/djiled.sh && cp -r /sbin/djiled.sh ./sbin/ && chmod +x ./sbin/djiled.sh
Try editing only djiled.sh and making the changes via telnet. Seems to be working for most people on here.
this the error
Starting kernel ...
Try forcing a downgrade (it will fail) and then doing this again. There are instructions on how to downgrade on this forum somewhere
Had sent my bricked copter and remote to DJI Germany and after 4 Weeks they sent me an all new setup back!!
I tried to change the bios of my 8 month old Phantom 3 Standard (ca.400 flights) from EU to US, to fix this range problem and you know the rest of the story.. NO WIFI and **** ^^
Now I got a brand new Copter (US), Remote (US), Propeller Set in a bag, Charger (US), Tool Set etc. FREE OF CHARGE!!!!
I can´t believe that but thats the truth. :D
i cannot fint frimware for p3 4k. for cr and drome
i already tru downgrade the drome using p3s but it fail
Reactions: paulgun
I can´t believe that but thats the truth. :DView attachment 59741
Welcome to the forum! I'm glad someone's had a good experience with DJI's support department - they were next to useless when I wanted support.
Reactions: HerrRuin
Helen Y West
