- Joined
- Sep 13, 2016
- Messages
- 23
- Reaction score
- 2
- Age
- 39
Will the instructions you gave me a couple posts up for connecting apple devices to the go app work on my A1432 model?Do you mean A1432?
Ok thank you for your help can you point me to a list of compatible devices for DJI Go App please. Thanks again for all your help and patience.The A1432 is an iPad Mini 1. That's not compatible with DJI GO.
The root is the main level on your memory card. The BIN should be in the root (just like all of the sub folders). If you put the BIN in one of the sub folders, your Phantom will not be able to find it.When putting it onto the root directory does that mean I put it in the sub folder under DCIM?
That usually means one of the following:I have not been able to generate a text file. I suspect I am doing something wrong in the questions above.
Just followed your steps and all went well. Only question is on multiple batteries. How long should firmware update take when inserting 2nd, 3rd, etc battery. Does each firmware release also update batteries? I just update to 1.10.90 and when I put 2nd battery in I got green status indicate in about 30 seconds. Thanks for your help.Correct. But, if the firmware on the memory card matches the installed firmware, it will not install. You should see a TXT file either way. Perhaps you missed some steps in the installation process? There are many so it's easy to do it incorrectly if you're not careful.
It usually takes no more than 1-2 minutes.How long should firmware update take when inserting 2nd, 3rd, etc battery.
No.Does each firmware release also update batteries?
If it works leave it alone[emoji106]
Yes, you should charge them before installing new firmware.Can batteries be fully charged for upgrade?
All should be fine if you follow my instructions at the top of this thread.Will it go all okay if I never did upgrade and I have first version of everything?
Plan for about 15-20 minutes for each firmware version you need to install.How long time does upgrade of everything take (assuming I have first version of everything)?
Follow these instructions exactly. Per the instructions, you'll need to install 1.3.20 on your Phantom before installing the latest version.How to proceed exactly if I got those versions?
