Help
Got a p3p I can do everything apart from seeing what my camera sees it takes vids and pics and I can watch them on my tablet but can't see the live feed any one have any ideas thanks guys
More details please. New aircraft? Used? What app? What tablet? etc...
Used aircraft tablet I've used samsung a6 samsung phone and samsung tab s2 I've used all if these on my other p3p
Ok, so this is a used aircraft? When you purchased this, did you have it demonstrated prior to purchase?
It's was sold as spurs or repair the hand set wasent paired to the bird that was it I can fly it just as good as my other everything controls as normal I just can't see live feed I've recorded with it took card out played vid back perfect on my laptop
Without more detailed information, not sure that I can give you a good answer to proceed. I presume that this AC came with it's own RC, correct? If so, and it is paired correctly, as you say that it flies fine. Then it is possible that this AC has a bad gimbal board. That is not a definitive answer by any means. Do you get a "NO IMAGE TRANSMISSION" notice when you fly?
Yes it came with it's own rc I even made sure by pairing it to the bird first it fires up the green light on front of gimble is on and I can fly and record no problem and there is no error message on my screen I'm lost to what the heck is wrong apart from no live feed the bird flys just as normal as my other p3p
Did you try a different USB cable?
Also, let me ask you this. When you fly, do you have telemetry?
Yes I used the one off my other p3p still nothing I thought that strait away but hope tried to upload small vid just to show it videos perfect but kept saying to large
I wish there was someone that was close to Crewe I Cheshire that I could take it to too look at it
Hight speed distance gps ?
Yes that is what I referring to. If those are displayed, but you have no video feed then I suggest there is an issue with the aircraft. Both of these are transmitted back to the RC on the same channel. If you have one but not the other, then to me that suggests, as I said a problem with the gimbal board.
Oh right ill have to look for new gimble board try that if not it's good spair for my other but thanks fir all your help
Found this post from no transmission signal,,worth a try
Reactions: MotorCycle-Man
thedrinklabsus
