help with the gimbal/camera wires
OK I posted this question a few days ago somewhere and I cannot find it. I opened my new to me (used) Phantom 3 Pro shell to look at a bump in the shell where the top and botton shells meet. Checked it out no problem, but I did see the grays wires that go from the mother board to the camera were nicked or pinched. So I thought I would check these wires for continuity and I found none of the 8 wires had continuity. Is this right or am I checking them wrong? I have batteries to test the gimbal movement but they need charged and I am waiting for a charger to be shipped in.
This may help you:
If you have any additional pinout, write an "issue" there and they will update the wiki.
You will find functional diagrams of all boards there, and descriptive pinouts for most connectors.
Reactions: RodPad
This may help you:
Thank You
All I say is flat cable looks pinched or nicked and all wires are open seems improbable but not impossible.
You are correct, I rechecked the white connectors on the gray wires and found that I had to you use a straight pin connected to my meter probe. This allowed me to get into the silver strip inside the connector for each wire. All wires checked out positive.
Reactions: DoomMeister
