Help with gimbal/horizon when turning
Hello,
I'm looking for help with the camera when turning or rotating the drone. If I have the P4P hovering and start rotating (even if I rotate as slowly as possible), the camera will tilt as I'm turning. It's driving me crazy! I've tried both follow and FPV mode under gimbal settings, and to be honest, don't appreciate that the behavior is any different. I have calibrated both the IMU and gimbal a few times, and even upgraded to latest firmware just to check. No luck. Is this normal behavior??? I really thought I could remember a time when it wasn't that bad? I can't stand this effect in my videos.
Here is an example of more pronounced affect by rotating 360 degrees more abruptly:
Thanks,
Scott
Did anybody ever find a solution to this?
I have just bought a Phantom 4 Pro with exactly this issue and no amount of Resetting or calibration seems to fix it
Another one here with the same issue, Firmware Upgrades, Downgrades, Calibrations don't seem to fix it. Anyone Solved the issue?
mine is also a P4P
