Help with Airdata
Hi All,
I was flying at a beach while on a holiday and I almost lost my drone as signal was lost half way through the flight and RTH kicked in. The drone was heading straight into a hill on the way back. I know I should have adjusted my RTH height limit to above 30. I was very lucky that I gained the signal back less about 1 meter before the disaster and somehow canceled the RTH and flew the drone back to safety.
Can someone help with analyzing what went wrong there and what might have cause the loss in the signal
Airdata UAV - Flight Data Analysis for Drones
Thanks in Advance,
Raghid
The airdata info is rarely helpful to the data experts who read these posts. Nevertheless, I don't know if there is anything in the DJI flight log that would explain signal loss; only that it happened. Hoping someone could explain the minor signal errors.
Reactions: Raghid
Hi All,
Thanks in Advance,
Raghid
The fact that the drone would have hit the hill heading back to you is a rather clear indication that the hill came between you and the drone as it descended behind it from 264 ft to 111 ft - hence the signal loss. That also appears to be the case from the limited information that you chose to share from AirData. If you want a definitive answer then you need to enable user download of the csv and kml files from AirData.
Reactions: Neon Euc and Raghid
Thanks for your quick reply and my apologies as this was the first time I share a report through airdata. Never used it before.
Please try the below new link:
Thanks
Thanks
For some reason that log starts in the middle of the flight, at around 244 ft AGL. Apart from that, assuming that you were controlling from the location where it finished the flight, the answer is that you simply flew it behind the hill, which is always going to cause signal issues.
Thanks
From the airdata image, it appears your home point is off-shore. Or is it just a thing with the tides? Were you located at the home point?
Just a wild guess, but you launched from a boat which started to drift into the shoreline at which time the hill came between you and the drone?
Reactions: Raghid
The home point is not only offshore, it's 244 ft in the air. I'm guessing that the location of the controller was where the aircraft landed. The following image shows the viewshed from the point where signal was lost. If that's the case then it's not surprising that it disconnected.
Reactions: Raghid
Yup. Never seen that before. The first entry log on airdata has it 244 feet in the air and 288 feet from home 30 seconds into the flight. Signal lost as it appears to go around the bend.
Reactions: Raghid
This flight appears to have been manual under Litchi, so it's possible that it launched with DJI Go - hence the partial log and the strange home point.
Reactions: Raghid
Thanks everyone for your valuable input. Looks like i have a lot to learn. i have actually launched the drone from where it landed. I was using the litchi app. Few minutes into the flight the app crashed and closed itself so i opened it again and everything was normal tell i lost the signal and rth kicked in. Not sure if thats the reason for the new home point!
Right - so the main lesson here is that you will lose signal if you put solid earth (hills) or even large buildings between the aircraft and the controller. This is essentially line of sight communications at these frequencies.
Reactions: Raghid
The home point issue is interesting, because the aircraft's home point was clearly not the location recorded in the Litchi log - when it entered RTH it set a heading of 240° direct for the takeoff location on the shore rather than heading for the Litchi-recorded home point. Also the Litchi log does not include a home point recorded notification, so the app seems to have simply assumed that the first logged location was the home point. That would appear to be a Litchi bug.
Reactions: Raghid
Lesson learnt. Thanks
Reactions: sar104
Although unlikely, it is also possible that the OP accidently changed the HP mid flight, especially after an app crash. Don't ask me how i know this! ::)
But that clearly did not happen, since when it started RTH it headed for the original takeoff point.
Hi All,
Thanks in Advance,
Raghid
billyboy02
