- Joined
- Mar 31, 2018
- Messages
- 1
- Reaction score
- 0
- Age
- 40
I couldn't find this topic anywhere else, apologies if it's been covered.
I'm a graduate student looking at modeling wild pig damage on crop fields using a newly acquired Phantom 3 Standard and Parrot Sequoia. I'd like top fly the Phantom without the standard gimbal camera attached, and have mounted the Sequoia in its place using some 3D printed parts, wire, and zip ties.
The way the Sequoia is mounted to the drone, they do not connect with each other electronically (I'm running the Sequoia off of a USB power supply). The big issue I'm having is getting any flight planning software to connect to the drone without a gimbal attached. This seems to be an issue with every planning software I try: DJI Go, DroneDeploy, Precsionflight, and UCGS.
The drone will connect to all of the apps, but when I try to upload a mission, it times out. If I try with the gimbal attached, it works. I'm worried that it's a hardware issue and the planning apps simply MUST communicate with the gimbal for some reason. Am I missing something simple? Is the GPS located in the camera/gimbal setup?
I could attempt to hardwire the drone to the Sequoia, but it was a step I was hoping to skip.
Any advice that could be offered would be excellent.
Thanks!
Thanks!
