Help DJI go with phantom 3 professional
Hello, i'm newby,
I have same problem with phantom 3 professional and latest version of DJI go.
The signal video is not good also when the drone is near my radioconteoller.
but if I use Litchi all work very nice.
the firmware inside of my ph3 pro it it latest.
What can I do?
I live in Italy
My phone s Mi5s plus 6gb ram
It is powerful enough.have you made sure all other apps are closed. If you run DJI go make sure litchi is not running in the background and try too kill off as many apps as you can
Ok, I'll try when I back at home.
but I remember going already done.........
I'm guessing DJI-Go is more bloated than Litchi. (DJI has more settings, more aircraft, Etc).
Anybody else got the better answer?
This question has came up before.
Rod
How I can do to see if my controller, battery and drone have latest firmware?
then what are they the version code number firmware for Drone. remote controll and battery?
dji go also informs me for example, if only controller or battery needs updating?
Controller yes, I can’t remember if it says battery might need update or if it just does it when FW file is on SD card. It’s been a while since my P3’s have been updated.
maybe it's better to put the firmware back into the sd and try to update the remote control again.
you can take a screenshot of the dji screen of the installed versions of firmware, so the comparison with mine.
This is what I have, DJI GO says all up to date.
Ok, I'll see when I back at home .
but my app version on my android smartphone is 3.1.43 why?
I don't think firmware is going to fix the problem.
This Statement is really vague,
"The signal video is not good also when the drone is near my radioconteoller."
What does "signal video is not good" mean?
Rod
