Yes FlynFrank,
Long long time, I'm more p2, always have been, but the 3's have always interested me ( lightbridge ) mostly!
I agree upgrade as a last resort, as I'm a STRONG believer of " IF IT AINT BROKE, DONT FIX IT! "
But that being said
This aircraft is doing really strange things, not sure why, not just the app issue! Which is obviously priority!
I'm going to try a few more things before the upgrade, as MSinger suggested! ( which may be my only option at this point ) so A+ there!
I'm finding there is A LOT of hush-hush, when it comes to diagnostic or tricks of the trade with these. No one wants to spill the beans!
Like for example
( p2 )
TX reset ( open Tx and press hidden button on mainboard )
Phantom 2 hard reset
( open bird place jumper from F1( bottom pin ) to F2 ( bottom pin ) turn on bird, naza reset to ver. 00.00.00, then you can instal whatever firmware is avail!
( there will ALWAYS be a back door )
Those of you old timers ( those who been here a WHILE )will know what I mean ( door-test-125 ) firmware revert on p2 ( don't worry no longer avail! )
Lol
Anyhow
P3 should be no different ( at least I hope not )!
I believe I've figured out how to hard reset the Tx,
going to test theory tonight!
I believe Button combo sequences are the key to it all!
( you know I can't help myself )
But the bigger question:
Does ANYONE, know the secret to HARD RESET P3p?
This might be a better solution? As of like to keep 1.8.8 ( or at least reload it ) and not 1.9.0. ( if I can )
Plus Id like to know, even if I choose another route!
As of now
Still no connection to app. With any device, bird still weird on startup.
Camera looks good ( green led after initialized ) but I go from normal red/yellow/green fading lights on bird, upon startup to instantly 3 fast yellow pause, 3 fast yellow pause, several times, to a very fast blink of green lights, after this goes straight to fast yellow ( Tx signal lost ), Tx is on , green led ( linked ), 4 white bars, while yellow on craft is flashing, I can turn off Tx, flashes don't change! Constant fast yellow! Until I turn bird off, and restart, then carbon copy all over again, plus occasionally the camera starts at a 45 degree ( roll axis ). But then next time perfectly level, ?
So I'm off to attempt some theories!
I'll let you know,
your time is GREATLY appreciated!
Thanks!
I know I might be going a little fast and ahead of myself, but this is ALL stuff is like to learn! ( weather I use it or not )....
J Dot
