H4-3D Problem (vibrating)
I just installed the new h4-3d on my phantom 2 and when I took it for a test flight I noticed very bad shaking of the gimbal. I did not attach the anti interference board because I didn't think I needed it (my h3-2d didn't). Is that the problem? Please see the video below.
http://youtu.be/34AXmhi8eQU
-Michael
ianwood said:
Do not use gains to get rid of gimbal vibration.
It will not fix.
People don't spend time reading the manual and try to find solutions where they aren't solutions.
Install the anti interference board and will fix it.
Ok, thank you. I did try adjusting the gains and it didn't work. I will install the board and hopefully that'll fix it.
thank yall!
-Michael
You can always send it back for repair or replacement. Use the warranty while it lasts.
My H3-3D gimbal vibrated visibly on my Phantom's first flight. Switching to the spare set of props fixed the problem for me.
Change to default gains. Then change to the stiffer dark grey dampeners that came with the h33d.
dlr11164
