Goodluckbuy 2-axis Gopro 3 brushless gimbal tutorial/review
Re: Goodluckbuy 2-axis Gopro 3 brushless gimbal tutorial/rev
First of all: take it easy, man. Its a cheap 140$ piece of chinese ebay merchandise... A friend of mine didnt get his 800$ zenmuse gimbal to work... well THAT sucks
Depending whether your on a mac or a pc theres different options to flash the hex files to the board. For pc theres a simple gui i think and for mac you need to use a command line in terminal. I have that command saved somewhere but i'm not on my computer for the weekend.
Check this page for the uploading software:
http://www.simplebgc.com/eng/downloads
As for the nulled firmware check post #18 of this thread: (looks like theres a v2.1 now)
http://fpvlab.com/forums/showthread.php ... ease/page2
If you do not get any clear readings from the IMU, well then the board might be damaged. This was the case with my gimbal, so i contacted the seller and i got a new sensor board.
Hello!
(Apologizes in advance because I'm new to this forum)
1) Does anyone know the weight of this gimbal? :?: :?
2) I've heard good reports on an aluminum gimbal from GoodLuckBuy.com
The sku is 98952 and this is the link:
http://www.goodluckbuy.com/dji-phantom- ... lalck.html
This gimbal appears to be shorter and doesn't require an extension to the landing gear. It also keeps the weight up higher - an apparent advantage. :)
The only disadvantage seems that it is probably be heavier. :(
PLEASE COMMENT :?
I have that exact one. I can't weigh it at the moment as I'm away from home until Monday. Will get a figure for you when I get back.
It's pretty light.
mine should be here any day now, glad i have read this thread ...fingers crossed :D
tom sauter
