P4 remote fix works great.
N.central wv. U.S.
I have had remote battery problems in the past. I did the heat gun fix. It worked for a while then I had to do it again. That lasted a few years. I like taking out my P4 once in awhile. It flies like a luxury car dŕives compared to my mini 3 pro. The power and the handling is fun.
I went to fly it last week and the remote had one light and kept beeping. It would not charge. I Googled the problem and found a you tube site that had a super easy circuit to install on the remote. It consists of two resistors. One is 80k, but I had to make it with 3 resistors in series. The other is 100k. Put everything back together and 3 lights came on. I charged everything up and had a great flight. Here's the link.
So you have to leave that mess of wires in place? was this just to show it worked and then i assume you tidied it up
Reactions: captainmilehigh
Reactions: crash1sttime
I had mine very neat. I put my 3 resistors together (to make an 80k) very close in a straight line from battery to v cell. The 100k came from the lead going to v cell to ground. Resistors wires are very stiff and stay in place off the board and under the top cover.
Reactions: msinger
The P4 remote fix really makes things run smoother. If you’re on iPhone or iPad, you might also want to check out Gcmob iOS, which helps manage and monitor devices directly from Apple platforms.
