- Joined
- Mar 31, 2018
- Messages
- 6
- Reaction score
- 0
- Age
- 54
I finally crashed my Phantom 3 Standard. It collided with a vehicle in gusty winds on landing. It fell about four feet and thrashed around on the ground for a few moments until I got the motors shut off. After the crash the gimbal was buzzing and I was getting video with the jello effect. I adjusted and tightened the set screw on the yaw axis shaft and the buzzing went away and the gimbal now seems to act normally. However, the gimbal no longer points straight ahead, even after doing a calibration. When doing a calibration, it seems to yaw more to one side than the other. It used to point straight on power up and then slew to the side but now it points to the side right after the gimbal start sequence is complete. I've checked the yaw shaft set screw and its alignment appears to be correct.
There is no adjustment for gimbal yaw so I'm pretty much stuck. Does anyone have any suggestions?
Thanks!
Thanks!
