Standard Gimbal pins
Discussion in 'Phantom 3 Help' started by Larryl67, Jan 31, 2016.
  1. Larryl67
    are the gimbal pins reuseable?
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    You can reuse them if you're able to remove them without damaging them.
  3. nix240z
    yes, slide the top back on to the thicker part of the shaft, you have to do one side at a time. Let them sit there for a while, then quickly push the top off. If it does not come off try again by doing it again but wait longer. Sometimes it takes me a few tries. They will go back to correct shape and resnap in place once installed again.
  4. Larryl67
  5. hunch
  6. With The Birds
    Australia
    Or just replace with loosely installed cable ties. You will get as or better function of the shock mounts with less chance of gimble and canera comming off in a hard landing.
Similar Threads - Gimbal pins Forum Date
Professional Gimbal Cushion Pins Phantom 3 Help Apr 8, 2017
Replacement Gimbal Camera Pins Issue Phantom 4 Help Sep 12, 2016
Easy way to remove gimbal pins without breaking them? Pro/Adv Discussion Feb 17, 2016
A quick question about gimbal mount pins General Discussion Sep 24, 2015
Gimbal Retaining Pins Zenmuse H3-3D/H4-3D GoPro Gimbal Aug 2, 2014
