Gimbal broke off
I am sure everyone heard this one before, but I crashed my Phantom 3 Standard and the gimbal broke off. It also tore out all the wires and the plastic end for the ribbon cable that goes into the gimbal itself. I found a site that sells the gimbal mount for $25, but I can't get the ribbon cable connection back in the tiny hole. Any help will be much appreciated.
Andy
patience required and you can put the connector back in and then glue it down.
you will also need both antennas as i see that both connectors are still on the main board (gimbal) which means
the antenna wires pulled off, hence new antennas.
