fpv problem ?
Flying today to check range on my new antennas (fatshark antennas, immersion rc 600 transmitter mw)
600 m and i lost fpv connection on approx 100 m hight
Is that good or bad ? Maybe normal ?
Try switching channels on the transmitter. I had the same. After I switched channels I went from 600 m to 1500 m range
Reactions: 750r
If you have a channel scanner on your FPV, try getting 10 m or so away and scan for the best signal. Mine chooses 7 and I've gotten as far away as 1.1km with video on FPV still pretty good. I have the lilliput with stock antenna.
I forgot to mention that I also use the ImmersionRC 600 mw transmitter
I have same transmitter + black pearl
unfortunately I don't have channel scanner so I need to try what is best
I also have fatshark antennas
