flights shaky
I had a crash that wasn't that bad (only dropped from nine Ft) but now I have two problems.
1: flights are now real shaky even with new props
2: the gimbal doesn't stay straight and the controller no longer wants to tilt it.... it just stays looking straight and doesn't move regardless of the knob being pushed.
On the frame of the quad, there's not really any BAD damage, just some scratches but no bent arms or anything
You can take off the Gimbal to see if it is making the phantom shaky.
after take it off recalibrate the compas.
Also You can, whitout props, turn on the phantom and see/ listen if some motor work diferent than the others.
Reactions: z3r01
Do you have video signal on the monitor? I mean if the phantom send video signal to anything you used to monitor?
Reactions: z3r01
I took the props off and listened and they all sounded the same. I also always recalibrate the compass as mentioned before take off . I also tried flying without the gimbal and still shaky
Reactions: santitimerman
Sorry thas all I can help you.
I think thaths maybe the shell is the problem.
Do you open and check that all the parts are hold strong one to heach other?
I will investigate and if I have news y will tell you.
Good luck
Reactions: z3r01
heres the insides, all looks good, one arm has a scratch but irk...I'm going to do a hard reset just in case.
I am sorry. I can't help you.
good luck and when you found the solution please tell me. I want to know what happened.
You have to download the phantom assistance software from dji web. And the drivers for the phantom.
Then open the software, register and login.
After that conect your phantom and look the calibration imu funcion. Do the advance calibration.
Good luck.
jorge sanchez
