Firmware Update Question
My P3A should be here later this week, and I had a quick question. Do I install the latest firmware update for it (1.9.60), or do I have to install an older firmware update before this?
The process seems quite easy, but I want to make sure I download/install the correct firmware on my new bird. Thanks!
You can find detailed firmware installation instructions here.
I see that version 1.3.20 needs to already be on the unit before updating the firmware. My guess is that any new P3A would already have it at this point. Correct?
Most probably will, but you should verify.
You can find the firmware versions in the "General Settings" --> "About" section of DJI GO. Those versions will only appear there when your Phantom is connected to DJI GO.
intertronixlabel
