  1. Madpunters
    Posting this on behalf of a friend with the below problem.
    I made the mistake of trying to upgrade the firmware with DJi app, seemed to go okay but then lost connection between devices about 60% and failed, drone still flew but couldn't connect to camera.
    Downloaded latest software for pc and tried using the DJi Assistant 2 same result upgrade failed this time at 70% error code 0002.
    Any tricks/ links or ideas on how to make the firmware upgrade work or reset to original will greatly appreciated ?
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Your friend should try the following (in this order until the issue is resolved):
    1) Reinstall the firmware via DJI GO (like this)
    2) Reinstall the firmware via DJI Assistant 2 (like this)
    3) Reset the firmware via via DJI Assistant 2
    4) Get the firmware upgrade log (like this) and contact DJI support for help
    If your friend needs more help, it would be easiest if he/she posted here directly.
  3. Madpunters
    Thanks for your help msinger. Have passed your info on. Hopefully it will fix the issue. Cheers
  4. Mus
    Mus
    Thanks for your help guys,
    Unfortunately still seem to be having problems with firmware.
    I have followed the advice in the links supplied and downgraded the RC to V1.580 and formatted the SD card > started aircraft and RC > connect RC to Ipad Pro, opened DJi Go and wait till upgrade message appears > disconnect from RC and connect to aircraft, the message appears again > download the upgrade and start updating.
    I then get a popup message around 45% saying "Cannot use device" "DJi device not supprted" this message goes away.
    Around 65% I get another popup "Unplug and re-plug data cable to refresh aircraft status" if I ignore this the update gets to 99% without ever finishing.
    If i unplug & re-plug the cable when it asks same result 99% forever.
    Tried updating via DJI Assistant gets to about 50% and displays message "lost connection to device" several times then seems to reconnect before failing around 65% with 0002 error, tried restarting aircraft/ re-entry, just keeps failing.
    I've upload a report from the failed upgrade so hopefully might lead to some answers.
    I think the problem might have started when i inadvertently upgraded the RC first.
    In desperation I tried applying update to RC via the DJI GO, current version is now 01.02.0503.
    Connected to aircraft current version is also 01.02.0503, neither come up with any available updates.
    I calibrated the compass and flew around a bit the problem now seems that the camera works initially then fails with "No Image Transmission Signal"
    Overall Status has a "Air Encoder Error: (0x2800020), suggests restart aircraft again the camera works the fails.
    Any thoughts or is it a job for support?
    thanks again, Mus
Similar Threads - Firmware update error Forum Date
P4P Camera Sensor Error after firmware update Phantom 4 Pro Help Aug 13, 2017
Attempt to download new firmware. Update failed error code 0003 Phantom 4 Help Jul 30, 2017
P3 Firmware P3 Adv Firmware update error Firmware May 20, 2017
after firmware update p3a getting esc status error Pro/Adv Discussion May 13, 2017
Advanced Esc error after 1.10 firmware update Phantom 3 Help Jan 15, 2017
