- Joined
- Oct 10, 2016
- Messages
- 207
- Reaction score
- 57
- Age
- 64
Did a search here and didn't find anything...how do people put their FAA # on a Phantom 4? Any suggestions welcome...
Up until recently Commercial UAS had to go through the paper registration process which assigned us a genuine N#. This process is still available should you want to (I can't imagine why you would) or if someone doesn't have access to a computer to use the online portal for registration.Newbe here, first time on this thread. This for US pilots only. From my understand you do not need a "N" number as long as you only fly in the US but you do need your registration available. I have mine in the battery compartment of my phantom 4 and another copy in my drone backpack.
You don't need an N number for recreational flying.BigA107 thank you for your response. Like I said I'm a newbe and I may be barking up the wrong tree. I was having a hard time with what was required until I figured out that Registration and the "N" number are two different things. Example of a "N" number is N1234D (delta) and a registration number is ten characters long or at least mine is. In my thread I quoted that the FAA will not include the "N" prefix and why and that is why I was unable to find it in any regs including the links you supplied. I know that you may request a "N" number but it is not required if you only fly in the US and under 55 lbs.
Buy yourself a small hand held label maker... works greatDid a search here and didn't find anything...how do people put their FAA # on a Phantom 4? Any suggestions welcome...
