ESC status error, persists even after multiple restarts AC 1.11.20
In case you need to replace the main board, there are 2 versions as there are 2 type of motors, that's was with PRO and ADV.
For standard I don't know if it apply, maybe only new motors.
Retrieve DAT logs from the FC. Either publish one or analyse with DatCon and tell us which non-zero ESC Status it shows.
Find unofficial firmware update 1.11.30.
To a wider audience - any suggestions on how this chart should continue?
Fix ESC Status Error on Ph3 Pro Ph3 Adv or Ph3 Std
Thanks, after a bit more into this it seems to be related to one of my four battery’s and only when the battery is at 20%. Full battery, no issue. Very odd.
So probably something works with a small margin to incorrect value... Might fail at some point. But if the parameters are exceeded while in air, AC will not shut off motors. So it is bit of a risk, but I'd say as long as it allows you to start, you'll probably be ok. Just don't fly above people (but you should never do that anyway). Every quad will fail some day anyway.
Reactions: PKapatos
hcashmore11
