ESC error on dji phantom 3 advanced
Hello. Sorry for bothering you. Im David, im from Croatia, thats a small country near Italy, so as you can see im very far away. Here is only 2 services for dji drones, and they are very expensive. I bought a cheap dji phantom 3 advanced, i have never flown it because it shows esc error, but the seller said everything works, so he cheated me. I would like to have an advice from you. As i was looking online, if there is esc error , i need to desolder esc (mosfet) on a main board on a phantom, and resolder another esc. Is that correct? Im in need of help so im contacting you for a free advice. Thanks for taking the time to read this. Have a pleasant day. David.
I put older firmware this is what i get -------------------
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3S_FW_V01.09.0060.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:13 remo-con disconnect======
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: P3S_FW_V01.10.0090.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:01:23 remo-con disconnect======
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:02:53 remo-con disconnect======
========== 2017.05.04 11:05:30 =====================
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Abort.
========== 2017.05.04 11:57:22 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2017.05.31 18:08:19 =====================
Result: Abort.
========== 2017.09.24 00:09:10 =====================
Result: Abort.
========== 2017.09.24 00:10:57 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2017.10.13 14:29:51 =====================
Result: Abort.
========== 2017.10.13 14:32:47 =====================
Result: Abort.
========== 2000.01.01 00:03:01 =====================
Result: Abort.
========== 2000.01.01 00:04:18 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2000.01.01 00:00:22 =====================
Result: Failed.
========== 2000.01.01 00:01:27 =====================
Result: Failed.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2000.01.01 00:00:24 =====================
Packet: P3S_FW_V01.11.0020.bin
Upgrading ...
Result: Failed.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Failed.
Result: Abort.
Result: Abort.
Packet: P3S_FW_V01.11.0030.bin
Upgrading ...
Result: Success.
And this is what i get with a new firmvare directly from the dji page
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Result: Abort.
Result: Failed.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Failed.
Result: Failed.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Failed.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Failed.
Result: Abort.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Result: Abort.
Result: Failed.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Failed.
Result: Failed.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Failed.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Failed.
Result: Abort.
You are installing the firmware of the phantom 3 standard. The firmware should start with P3A_... The one you are installing start with P3S_ which is for the standard. Make sure you download the right one.
This is incorrect. The firmware bin file name for the P3 Advanced begins with P3S. It has been that way since before the P3 Standard was released and is still true today.
He is showing the correct bin file for a P3A in his logs.
Reactions: JoBe and fancymark
pickwicknick
