I have read many posts on how to initiate the return to home and I am getting ready to use Lithci for the 1st time. In the event I lose control would the "BEST" way to initiate RTH be by turning off the controller, thereby cutting off all signals to the drone? I will be on our property of 100 acres farm land, flat and very few trees, just trying to have an emergency plan should something go wrong. Thank you for your thoughts on this.I will be flying phantom 3 standard
You don't mention "mission" anywhere in this thread so I assume you're talking about normal flying with the Litchi app.
Regardless of what app you're using, the best way to deliberately initiate RTH is with the S2 switch (see your manual). Once RTH begins, your app should indicate that you're in RTH. This is the best way because the log on your mobile device will remain intact.
If you lose the 2.4 signal and you can't see the AC in the sky, you won't have any confidence that the S2 switch is working (.i.e. you don't know if you have a good 5.8 connection), so in that case, yes, turn off the controller. It must RTH after 3 secs. But know that (my understanding is) your log on the mobile device will end and a new one will begin when you turn your controller back on (maybe that doesn't matter to you).
You might think "If my 5.8 is good, then the AC will sense the S2 switch, and if it isn't good, the AC will RTH on its own", but what has happened to other pilots in the past is that if the 5.8 is intermittent, the signal won't disconnect/RTH and the AC may not receive your RTH command from the S2 switch either. So the AC ends up landing somewhere due to low battery.
So yes, in an panic emergency, just turn off the controller. You can turn it back on later and cancel RTH and land it yourself.
